ugh... frozen and now stripped rearset mounting bolt on 1198sp - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jan 14th, 2012, 12:52 pm   #1 (permalink)
so i was installing my new rearsets...
and one of the four bolts connecting stock rearset to frame was pretty well frozen. being as careful as i can i tried to use elbow grease to loosen. bad mistake. stripped the inside of the hex bolt. now i have a frozen and stripped rearset mounting bolt.
a google search suggests penetrant and flame (really?!?). common sense suggests drilling out and retapping.
i would appreciate wisdom here!
2011 1198sp
2011 multistrada 1200s
2009 696 (my wife's lil monster)
2006 bmw r1200gs (gone but not forgotten)
bartman314 is offline   Reply With Quote
Old Jan 14th, 2012, 1:36 pm   #2 (permalink)
998_SBK's Avatar
go to Ace Hardware
Ace Hardware stocks these:
PB Blaster Penetrating Catalyst, SKU# 19592
Ace Broken Screw Remover, SKU# 2192292
Both work miracles. Best wishes.
Automotive & Motorcycle Fine Art
http://www.j2automotiveart.com
998_SBK is offline   Reply With Quote
Old Jan 14th, 2012, 1:37 pm   #3 (permalink)
The Finder
nine16's Avatar
Images: 2
The frame threads are stripped or the hex head is rounded out?
Assuming you mean the latter, then I've never failed to remove a broken bolt with an easy-out:
EASYOUTS, EASY-OUTS, EZ OUT, EZY-OUT, Bolt Extractor, Screw Extractor
2001 Ducati 996 R
1998 Ducati 916 SPS #909
2001 Ducati 996 track bike
1971 Honda CB450 cafe racer
1989 Honda NSR250 MC18/derestricted
2001 Derbi GPR 75
2000 Ducati 996 SPS #1134(sold)
2001 Ducati 996 Monoposto(sold)
1998 Ducati 748 (sold)
1999 Ducati Monster 900 (sold)
1995 Ducati 916 (sold)
1997 Suzuki TL1000s (sold)
1994 Honda VFR750 (sold)
1988 Yamaha FZR1000 (sold)
1990 Suzuki Katana 600 (sold)
1986 Yamaha Radian 600 (sold)
1985 Kawasaki GPz750 (sold)
1983 Suzuki GS450E (sold)
nine16 is online now   Reply With Quote
Old Jan 14th, 2012, 3:32 pm   #4 (permalink)
Sounds like you stripped out the hex on the allen screw. If you can find a torx bit a little larger than the hex, you can drive it in and use it to turn the screw out. If that doesn't work, use a drill bit about the diameter of the threaded portion of the screw and carefully drill until the head falls off. You can then remove the rearset and turn the rest of the screw out with a pair of vise grips.
Next time, use a quality plain allen wrench to break them loose, not a ball end.
'09 Kaw Versys
'00 Kaw KLR650
USN Vet.
ttpete is offline   Reply With Quote
Old Jan 14th, 2012, 3:56 pm   #5 (permalink)
The Finder
nine16's Avatar
Images: 2
Fail. Just buy the right tool for the job. They don't cost much.
2001 Ducati 996 R
2001 Derbi GPR 75
Old Jan 14th, 2012, 8:11 pm   #6 (permalink)
thanks for inputs!
not quite sure what i'll try yet, but there are a number of good suggestions here and from the ducati@list.ducati.net.
i'll sleep on it and dig in tomorrow.
oh, i did use a good quality hex rod allen key. i bought the bike used and the hex looked a little funky to start with. in hind sight, i should have gone with penetrating fluid/heat before attempting to un freeze.
stay tuned for the next chapter.
2011 1198sp
Old Jan 14th, 2012, 8:22 pm   #7 (permalink)
Listen to ttpete. Tap a torx socket into the stripped bolt and use an impact driver on it.
Not an air impact, but a cam action driver used with a hammer.
lameshaft is offline   Reply With Quote
Old Jan 14th, 2012, 10:39 pm   #8 (permalink)
The Finder
nine16's Avatar
Images: 2
The torx option is fine to try first. If it doesnt work, no harm done. On the other hand, drill the head off and you may be past the point of no return.
2001 Ducati 996 R
2001 Derbi GPR 75
Old Jan 14th, 2012, 10:54 pm   #9 (permalink)
bpracer's Avatar
Eh, you could always heli-coil it if the threads got messed-up drilling the bolt out.
If it has a bunch of thread locker on the bolt, as Ducati very very fond of lathering on, heat can kill it. Maybe drive the torx head bit on to the bolt as mentioned previously and then heat the crap out of the bit to kill the thread locker.
06 PS1000LE Zard's, Hyperstacks, PCIII, 999 wheels and calipers
09 848 LeoVince/Fat Duc, Ohlins TTX and fork kit
65 Mustang Vintage Road Racer
bpracer is offline   Reply With Quote
What is the best way to repair a stripped bolt??? rocketbrothers540 Sport Classic 3 Aug 1st, 2011 12:04 am
Frozen Oil Drain Bolt??? Frustration Ducati Motorcycle Chat 11 Jun 13th, 2011 8:49 pm
HyperMotard Rearset mounting Bolt Bravo51 Parts and Accessories 1 Jun 2nd, 2011 10:58 pm
Stripped Allen Bolt (HELP!!) 2UpDuc Sport Touring 9 Feb 9th, 2006 6:18 am
