Spare Tank Storage - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jan 13th, 2012, 8:18 pm   #1 (permalink)
Spare Tank Storage
Have a spare tank with pump in the garage these days and don't want anything to dry out or otherwise. Can't see just filling it up with fuel, so any ideas?
Thanks in advance,
Jim
jimne245 is offline   Reply With Quote
Old Jan 13th, 2012, 8:48 pm   #2 (permalink)
Humble
Chuckracer's Avatar
Images: 2
Jim, how about filling out your profile AND letting us know a little something about what kind of tank this is...Sherman? Abrams?
Old Jan 13th, 2012, 8:52 pm   #3 (permalink)
safetyfish's Avatar
You dont want moisture or oxygen into the tank when storing for the longterm so?
Make sure these corrosion causing elements are removed as part of the process (dont store with fuel in the tank btw, the modern stuff has additives in it that attracts moisture so could create problems in the longrun)
Open tank and drain it of all fuel
Allow EVERYTHING to evaporate (including fuel in filter and pump. If it was me then I will disassemble the tank completely and manually drain and clean every component using compressed air.)
Use a fogging agent to liberally coat the inside of the tank. Spray it into the tank and try to reach all nooks and crannies then drain the excess liquid which may colelct. Finally throw a desicant bag in the tank and then close everything up. Stick a note on the tank to remind you there is a desicant bag inside of the tank.
Wrap the tank in wax paper, then box it and store it away with a few extra desicant bags put into the storage box to get reduce moisture content.
Basically, thats what I did to the Bayliss tank I have. (Metal fuel tank, not sure what they do to modern plastic fuel tanks)
Cheers
999R
998 Bayliss
safetyfish is offline   Reply With Quote
Old Jan 14th, 2012, 9:59 am   #4 (permalink)
ZetaTre's Avatar
If it's a Sherman or Abrams I'm not interested. But if it's for a 999 I'll exchange it for money and keep it filled up for you...
ZetaTre is offline   Reply With Quote
Old Jan 14th, 2012, 11:06 am   #5 (permalink)
I drained & removed my SS tank for the Winter, removed the cap body, dried out the tank completely to remove any traces of water/moisture (SS tanks are known for rotting on the back corners), rubbed a little engine oil on any rusty bits, wrapped it up good in bubble wrap & stuck it in a large padded box in the spare room. Nice and snug with no risk of condensation or damage having let it breathe a little inside first.
Unfortunately I went cold turkey last week due to our unusually mild Winter, refitted it, filled it back up and went out for a blat over the weekend...
470four is online now   Reply With Quote
anyone have a spare tank fairing? v12gte HyperMotard 8 Jan 10th, 2012 11:31 pm
Anyone have a spare tank for a 1995 900SS CR? Project 853 Supersport 8 Mar 22nd, 2009 7:19 pm
Spare 99 750 SS Yelow Tank anyone? ikan Supersport 0 Mar 10th, 2009 4:36 pm
NEw Tank Bag - Very happy with fit and storage pics.. Classicrobeuro Sport Classic 15 Aug 20th, 2008 10:13 pm
Anyone got a spare tank? theseeker411 Supersport 16 Nov 30th, 2007 1:38 pm
