Rear Tire - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jan 13th, 2012, 7:45 pm   #1 (permalink)
guardian707's Avatar
Images: 18
Rear Tire
Ok, I know im going to take some crap for this so dont be to hard on me, but will a 200mm tire fit on my 1098? I have done this on all my jap bikes but this is my first Ducati I just like the way the wide tire looks
Bob..
guardian707 is offline   Reply With Quote
Old Jan 13th, 2012, 7:59 pm   #2 (permalink)
and excessively wide rear tire isnt alway a good idea. To run a wider tire you need a wider rim. I dont know what size rim a 200mm tires is desinged for, but if its not meant for that application then it will mess with the handling of the bike. The reason is if you run a wider tire and dont have the right size rim the the tire will just buldge up making the bike sit higher in the back and not give you the proper contour the tire was desinged for. make sense?
bmxer4liffe is offline   Reply With Quote
Old Jan 13th, 2012, 8:03 pm   #3 (permalink)
Images: 18
Yes it dose, I would only do it for looks no track days for me just long day rides.
Thanks
Old Jan 14th, 2012, 11:27 am   #4 (permalink)
Images: 18
What's a good street tire? I like the dunlop Q2
Old Jan 14th, 2012, 10:45 pm   #5 (permalink)
Hyperdyne's Avatar
The 200mm tire will fit. However the choice of a street tire vs. a race tire may not net your the "look" you want. If you are looking for a street tire with a rce tire profile, the Q2 will work. Otherwise you will get a tire that when spooned onto your rim is going to cause your bike to handle more sluggishly than you intend.
Hyperdyne is offline   Reply With Quote
Old Jan 14th, 2012, 11:15 pm   #6 (permalink)
bpracer's Avatar
The new 1199 comes with a 200mm tire. I think there are a couple "wider" tires that are designed to maintain the proper profile.
I've heard there are new 190 tires that will work on my 5.5" 848 wheels, so I can see a proper 200mm tire working on a 6" wheel. Whether they clear your swing arm and exhaust is another matter.
06 PS1000LE Zard's, Hyperstacks, PCIII, 999 wheels and calipers
09 848 LeoVince/Fat Duc, Ohlins TTX and fork kit
65 Mustang Vintage Road Racer
bpracer is offline   Reply With Quote
190/55/17 rear tire on a 916-998??? angelo1000r Superbikes 2 Sep 16th, 2009 7:12 am
Rear tire seight311 Supersport 4 May 22nd, 2009 7:46 am
Rear Tire Too Big? scot Superbikes 15 Oct 3rd, 2007 11:46 am
rear tire???? franzl66 Supersport 23 May 3rd, 2006 4:04 pm
