Jan 12th, 2012, 4:02 am
Newbie Bayliss
Hey guys this is my first post here...
Just got a chinese fairing set and have a few questions for the learned bretheren here.
the plan is to build a 916 from the ground up, money pit here I come..
so first off I got a monopostal seat but the tail fairing was drilled for bipostal at the back... so it got drilled and not after a bit of persuasion fits.
Just got the front seat hinge from Germany and a Chinese LED tailight off Ebay.. next question how is the rear lock bracket fixed to the actual faring?? have the chinks missed something again?
Also I hear about UK american etc headlights ...is this just what light is on or are they different shapes? I say this because I'm just about to buy a headlight set from the Netherlands and f-knows what the Chinese based their moulds on.. any help appreciated.
Jan 12th, 2012, 4:41 am
Headlight shape will be the same!
Jan 12th, 2012, 5:39 am
The Finder
Way to make an entrance.
2001 Ducati 996 R
1998 Ducati 916 SPS #909
2001 Ducati 996 track bike
1971 Honda CB450 cafe racer
1989 Honda NSR250 MC18/derestricted
2001 Derbi GPR 75
2000 Ducati 996 SPS #1134(sold)
2001 Ducati 996 Monoposto(sold)
1998 Ducati 748 (sold)
1999 Ducati Monster 900 (sold)
1995 Ducati 916 (sold)
1997 Suzuki TL1000s (sold)
1994 Honda VFR750 (sold)
1988 Yamaha FZR1000 (sold)
1990 Suzuki Katana 600 (sold)
1986 Yamaha Radian 600 (sold)
1985 Kawasaki GPz750 (sold)
1983 Suzuki GS450E (sold)
Jan 12th, 2012, 6:53 am
Originally Posted by nine16
way to make an entrance.
+1
bruce19
'05 SS1000DS
'03 Audi A4 Avant
'05 MASI Gran Criterium S
Jan 12th, 2012, 6:56 am
Umm, a little bit more information would be good.
So is the subframe a biposto or monoposto subframe?? What are you trying to fit it on? You have a biposto seat pad, that much is obvious but I don't know if you always had that, if it came with the bike you are trying to build-up, or whether it was a one-off ebay purchase that you hoped would make a happy marriage with your newly acquired seat unit.
I suspect that the seat unit (from your photos) does not have the appropriate holes tapped to support the brackets for mounting the seat or the tail light. But that is just as much your fault for buying something without doing your research first.
Have a look at 2002 748 Biposto to Monoposto Conversion....Can I get a definative answer? to get a look at the type of brackets you would need if your seat unit had been tapped to deal with it. Whether it could be tapped?? Not a question I can answer.
As for the headlight, carlchurchill is correct they are all the same shape, but since the forum has no idea where you are from how would we be able to advise if one from the Netherlands is what you require?? It all has to do with what side of the road you drive on.
BTW It was more than a lot mean and more than a bit disrespectful to call the Chinese, chinks.
The search engine here is your friend.
Jan 12th, 2012, 7:46 am
Yeah, you run into a know problem with these Chinese fairings, which can be solved in several ways.
No problem to share how I did it, but should aprpeciate a 'slight' modification on your tone-setting in your intro first.
E.
2001 Ducati 998S (track only)
2002 Ducati 998S Bayliss
2002 Honda VTR1000 SP-2
2004 Buell XB12R Firebolt
Jan 12th, 2012, 8:32 am
[QUOTE=748girl;1256592]Umm, a little bit more information would be good.
I suspect that the seat unit (from your photos) does not have the appropriate holes tapped to support the brackets for mounting the seat or the tail light. But that is just as much your fault for buying something without doing your research first. no it has no holes tapped, How is it my fault that I bought a fairing that said Monoposto? There are no inserts or any type of hole in the rear. It will be going on a mono ally subframe.
As for the headlight, carlchurchill is correct they are all the same shape, but since the forum has no idea where you are from how would we be able to advise if one from the Netherlands is what you require?? It all has to do with what side of the road you drive on. I'm in Phuket.....we drive on the left
Ok First of all apologies to our Sino friends
are you telling me that I bought a biposto seat?
Here's a picture I got off google images af a mono and bi(the mono is actually the same as I bought from Ducatipartsonline)..thanks for your help
Jan 12th, 2012, 8:41 am
I had the exact sam eproblem when I bought some cheap ass fairings. I am at work right now and will replay in greater depth this evening when I get home. But it involved, plastic-weld epoxy, fiberglass matting, fender washers, nuts, solder and a dab of green paint.
Jan 12th, 2012, 8:50 am
I'm all ears
Jan 12th, 2012, 9:24 am
+2
ProphetPVD
'02 748R, #0954
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
'02 Bayliss #315
bruce19 |
Bikes |
38 |
Nov 22nd, 2011 9:04 am |
Bayliss suomy
duc_rider_1 |
Gear |
0 |
Jul 26th, 2011 5:44 pm |
Bayliss 996 ?
DucmanST3 |
Superbikes |
5 |
Sep 9th, 2008 1:35 am |
