Will the 2000 R1 throttle Tube work on a 2009 1198?? - Ducati.ms - The Ultimate Ducati Forum
Old Jan 11th, 2012, 3:53 pm   #1 (permalink)
McFly's Avatar
I'm looking to shorten my throttle twist (Quick Turn Throttle), I have read the threads about it and looks like a 00 R1 tube is the best answer? I would like to hear from you about it working or if there is a better way (Different year, better kit)? The more suggestions the better, just want to do it right the first time. Not in any big hurry,
Thanks, McFly.
2009 Ducati 1198s "My first Ducati and I feel like I have starting ridding all over again"
McFly is offline   Reply With Quote
Old Jan 11th, 2012, 4:26 pm   #2 (permalink)
Thanks, McFly.
I used R1 tube 4YR-26240-02-00 on my 848 evo.
Easy, cheap mod....
Not a massive difference, but enough to go from zero to hero in one twist.
nelson848 is offline   Reply With Quote
Old Jan 11th, 2012, 4:54 pm   #3 (permalink)
McFly's Avatar
Easy, cheap mod....
WoW, even a part number.
Thank you very much,
McFly.
Old Jan 11th, 2012, 6:08 pm   #4 (permalink)
ZetaTre's Avatar
Don't expect a quick action: it is definitely not. But on my 999 it removed 5-10 degrees, which makes it more of normal throttle...
ZetaTre is offline   Reply With Quote
Old Jan 11th, 2012, 6:23 pm   #5 (permalink)
Trackday Junkie
Mospeada's Avatar
I do recommend it. I certainly am not breaking my wrist anymore to go WOT.
If you want more, get an R6 throttle tube. But that's damn near an on/off switch.
Regardless, the throttle tube mod is probably the cheapest best mod you can make. For me, feels like the bike went up +2 in the rear sprocket.
But you also get a grip.....so....while you're at it.....
Ditch the concrete grips. Get a soft grip, one with a foam/gel on it. That will cure wrist numbness and soreness.
"No doesn't mean no; 'giraffe' means no....."
http://www.socaltrackdays.com/
http://www.chuckwallavalleyraceway.com/
Mospeada is offline   Reply With Quote
Old Jan 11th, 2012, 8:41 pm   #6 (permalink)
McFly's Avatar
R1 throttle tube Assembly on order.
Thank you all for the info.
McFly.
Old Jan 12th, 2012, 3:01 am   #7 (permalink)
McFly.
No probs...
The other great thing about this mod (at least on my bike) it completely did away with all the throttle slack - which I hate!
As someone said it only takes a bit of the turn out, but IMO enough, I didn't want on/off!
Good luck.
Old Jan 12th, 2012, 7:28 am   #8 (permalink)
No probs...
Good luck.
I've been tossing up between this and putting the DP quick throttle kit on the bike.. I already bought the DP kit but I haven't fitted it yet as I don't want an on/off throttle but I do want to be able to do WOT in one turn of the wrist unlike the factory throttle which is a fair way off that... thoughts?
jazza08 is offline   Reply With Quote
Old Jan 12th, 2012, 10:04 am   #9 (permalink)
Never tried the DP one, so can't really comment. Does it come with a selection of tubes?
The R1 tube is a s cheap as chips, so worth a punt IMO.
Old Jan 18th, 2012, 2:02 pm   #10 (permalink)
Put an R1 throttle tube on last night but its about 1/2" shorter than the OEM leaving said amount of "extra" clip-on showing on the end. The bevel is present on the tube so I know it hasn't been trimmed. Anyone else run into this problem? Remedies?
Tractionless is offline   Reply With Quote
WTS: DK & Evo throttle tube PhilDucati Parts and Accessories 1 Nov 21st, 2011 4:39 pm
evo sp throttle tube scrc51 HyperMotard 11 Oct 6th, 2011 8:36 pm
WTB xx9 throttle tube robob Parts and Accessories 4 Sep 19th, 2011 8:33 pm
R1 throttle tube mod SquireSCA StreetFighter 8 Jun 7th, 2010 5:08 pm
