Jan 11th, 2012, 5:54 am
Floating vs non-floation rotors pro/cons??
Almost ready to do it but not sure of the real value. My 95 900 SS/SP had them from the factory. Now they are I guess what they call them semi rigid. Definitely not the rattle float of the 95. So is there anything to be gained. Brakes seem pretty awesome on this 999S with out the float.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
Jan 11th, 2012, 5:58 am
You won't notice much difference unless you are tracking the bike to be honest.
Jan 11th, 2012, 11:20 am
Ducati.MS sponsor
They are not a huge difference- but there is a difference.
The full floaters tend to spin a little easier as they find space between the pads so you end up with less rolling resisitance. I notice it when I'm pushing the bike around.
Pads generate less heat and heat transfer to the brake fluid as you are riding because they are not always rubbing on the rotors. This can reduce brake fade.
Full floater buttons are usually aluminum, so they are usually 1/2 lb lighter overall. Not a huge difference in itself, but if you are trying to build a lightweight bike - every little bit helps.
-M
Jan 11th, 2012, 4:10 pm
Great points. I found in a thread that they can cause premature wear in the carrier contact area, but that could be 50K since no real mileage or type of ridding was given. Any one experience this?
Jan 11th, 2012, 8:54 pm
Super Senior Poster
I installed a set of Brembo HP rotors on my 999 (thank you MotoWheels!). I had axial calipers at the time, but it did make a difference in braking, feel. IIRC the OEM rotors are semi ??...the only downside, if you can call it that is they do make a disturbing clicking-creaking noise when your pushing your bike around....
Jan 25th, 2012, 6:00 pm
i love mine and the sound they make although these newer stainless ones from brembo aren't as noisey as the old cast iron.
the brake tech stuff is nice too in carbon, iron or stainless
cheers
paul
916 biposto 96' current
M600 00'
Mille S2 84'
Jan 25th, 2012, 9:15 pm
Floation?
It's time for a little Italian Education! 2012 Panigale ABS
Jan 25th, 2012, 9:24 pm
sound? noise? what??? who cares?? rotors are not suppose to sound cool, get whatever rotors produce the best results (aka braking power)...and/or last longer.
2010 Ducati 1198
2007 Kawasaki ZZR600 (sold)
Jan 25th, 2012, 10:52 pm
for best results replace discs with every pad change, so if you want best braking don't worry about the life of the disc. best and lightest discs on the market are the carbon discs, super light and lots of friction, work well on the road but they're not cheap. $1100 each last time i checked.
cheers
paul
M600 00'
Mille S2 84'
