Info on installing new pressure plate?? - Ducati.ms - The Ultimate Ducati Forum
Old Jan 10th, 2012, 3:25 pm   #1 (permalink)
McFly's Avatar
I have a 09 1198s and I just got a EVR pressure plate, springs and caps. I just went to install it and it's not wanting to fit flush, teeth in teeth. If I put the old pressure plate back on it does the same thing. I know it just moved or I'm not lining it up just right. Any info on what I'm doing wrong or not doing would greatly help.
Thanks, McFly.
2009 Ducati 1198s "My first Ducati and I feel like I have starting ridding all over again"
McFly is offline   Reply With Quote
Old Jan 10th, 2012, 4:31 pm   #2 (permalink)
On the end of one spring post is a notch. It has to line up with a mark on the pressure plate that'll be next to one of the spring holes. If you can't find it, try putting it on all six possible ways. One will be the correct one.
'09 Kaw Versys
'00 Kaw KLR650
USN Vet.
ttpete is offline   Reply With Quote
Old Jan 10th, 2012, 5:05 pm   #3 (permalink)
McFly's Avatar
Thanks I got that one, cut marks line up with the dot on the back of the EVR pressure plate. It almost seems like the push rod is not in all the way in or the black cap on the end moved?? I don't want to just put the springs back on and tighten, scared I might mess something up.
Old Jan 10th, 2012, 5:30 pm   #4 (permalink)
had the exact same problem recently. read the following thread, and my last post for the solution.
1198 clutch pressure plate and pushrod question
2010 Ducati 1198
2007 Kawasaki ZZR600 (sold)
avaipan2 is offline   Reply With Quote
Old Jan 10th, 2012, 5:30 pm   #5 (permalink)
Its easiest to pull the pushrod out and seat in into the pressure plate first. Then slide it in as an assembly
749D
999R fila #25
1098S Midnight Black
S4RS(sold)
Monster 695(sold)
http://www.flickr.com/photos/53868828@N02/?saved=1
jeremyh007 is offline   Reply With Quote
Old Jan 10th, 2012, 7:43 pm   #6 (permalink)
McFly's Avatar
Jeremyh007, Thanks you I was trying that just scared to damage it.
avaipan2, thanks for that thread, I just wiggled it and pushed on it for a while then it started to seat.
Thanks for all your help, McFly.
Old Jan 10th, 2012, 7:44 pm   #7 (permalink)
McFly's Avatar
Wow thats weird how I did that with the quote lol
need help!!! i don't know which pressure plate to buy DUC_999 Welcome and Introduction 2 Jul 13th, 2011 1:32 am
installing a new pressure plate? jeremyh007 Superbikes 10 Apr 19th, 2009 8:05 pm
Problems after installing a Pressure Plate on my 999s MixXxeR Superbikes 15 Jul 13th, 2008 12:56 am
clutch slipping after installing pressure plate dragknt Superbikes 20 Nov 7th, 2007 12:40 pm
DP pressure plate rjahr01 Ducati Motorcycle Chat 5 Aug 28th, 2006 1:21 pm
