999 street to race the easy way? - Ducati.ms - The Ultimate Ducati Forum
Old Jan 9th, 2012, 9:43 am   #1 (permalink)
ZetaTre's Avatar
This weekend I've picked up a set of "race" fairing to use at the track and around canyons while keeping the nice bodywork for cruising around showing it off...
The nose fairing came with the race frame to remove the whole headlight assembly.
Would removing the nose assembly be just as easy as removing the 2 bolts that secure the headlight assembly to the frame of the bike? Or do I have to remove piece by piece?
ZetaTre is offline   Reply With Quote
Old Jan 11th, 2012, 9:36 am   #2 (permalink)
froggert's Avatar
from what i remember, you have to open up the headlight housing to get to the plug. it's been a while since i've taken an 749/999 apart, though.
1098s, m620, m750
froggert is offline   Reply With Quote
Old Jan 11th, 2012, 10:01 am   #3 (permalink)
Extended Member
CAlexio's Avatar
Remove side fairings, then unscrew two bolts on side, then 3 underneath the headlight (above wheel)... That's it from what I can remember.
Old Jan 11th, 2012, 11:24 am   #4 (permalink)
ZetaTre's Avatar
Thanks guys!!! I tinkered with it last night. Removing the front end as a complete assembly is very easy, the problem is really the harness. It comes from the bike frame to the front nose (connected through a larger rectangular plug located about halfway under the tank alongside of the frame) and then goes back through some separate plugs (including one for the horn that runs all the way down to the horizontal cylinder.
The plan tonight is to see if I can disconnect the plugs in the headlight unit without taking it apart.
I'm basically looking for a way to completely swap bodywork in a matter on less than 30 minutes with the the minimum amount of work...
I'll play some more and see what I find. In the meanwhile if somebody has a front wiring harness with a rectangular plug laying around I'll pick it up...
Old Jan 11th, 2012, 11:30 am   #5 (permalink)
I usually buy a race faring stay so I can undo the entire front and remove it with the mirrors. Makes it much quicker. GOod luck
phil996 is offline   Reply With Quote
Parts - race / street - 748 998 916 996 ducatista Parts and Accessories 10 Aug 6th, 2010 10:04 pm
LV titanium - race vs street with no dbk's shawngibson Superbikes 23 Apr 7th, 2009 2:21 pm
Race leathers on the street? zbomb Superbikes 54 Jun 19th, 2008 5:54 pm
Power Race for the street? duc_748 Ducati Motorcycle Chat 22 Feb 13th, 2008 5:55 pm
Power Race... on the street? RickTv60 Ducati Motorcycle Chat 13 Jan 29th, 2007 11:51 pm
