Ducati 749s Fans not workings - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Jan 9th, 2012, 9:03 am   #1 (permalink)
Hi lads first/post thread and i hope you can help
I was doing some work on the 749s over the weekend and it showed up error codes 17.2 and 18.2 which are
17.2 LH Fan shorted to earth
18.2 RH Fan shorted to earth
Now ive checked all the fuses and wiring and all seem fine but im still getting these error codes. When i ground the fans independently they power on so no problems there
Im wondering if the thermostat was faulty could this cause the above problem and show up the error codes
Dewi is offline   Reply With Quote
Old Jan 26th, 2012, 7:19 am   #2 (permalink)
I had that problem on my 999 04 but only on one fan...
Check wires of the fan on back of the battery box. Heat from the exhaust knows to melt down the wire insulation so wires can be there shorted.
I attached wiring diagram for my 999...probably the same as 749.
lefi is offline   Reply With Quote
HID kit for ducati 749s drtb Superbikes 14 Apr 5th, 2011 4:49 pm
Ducati 749s boostede36 Superbikes 5 Apr 30th, 2009 7:07 am
Had a "small" meeting with some other Ducati fans. amullo Ducati Motorcycle Chat 19 May 15th, 2008 11:31 am
Any Ducati fans on here play MotoGP 07? KoiHoshi Ducati Motorcycle Chat 5 May 14th, 2008 9:21 am
