Originally Posted by Damien11B
Well now im running into problems left and right due to that i think..
When i hit the starter the motor would turn over like two times then it just spins. I noticed that when i get the motor warm it wouldnt have a problem starting.
Now when i try to start it up all i get is a clicking noise
So from there i have been told that it could be 3 different things... The starter solenoid , the starter itself, or the starter sprag clutch.. I dont wanna drop this kind of money on new parts if i dont have to..
If you have any of the parts listed above for cheap and they work let me kno please.. thanks...
Keith
If you click on my member link you can find topics on starting issues and troubleshooting your problem.
http://www.ducati.ms/forums/search.php?searchid=3074417
Look for posts that have either "Battery" or "Starting" in the title.
Most of the most useful are the earlier ones, so page through to them.
The posts should bring you up to speed.
I think your starting circuit is the issue but that's what you would expect me to say since I make a replacement.
So learn what you can from the posts and see if that helps you sort out the problem.
In general;
The solenoid is just a high current switch and (usually) either works or doesn't.
The starter can be damaged and pull so much current it starves the rest of the electrical system.
The sprag clutch also (usually) either works or doesn't (either engages and sticks - or doesn't engage). The spinning sound you hear when you stop trying to start is the sprag spinning backwards as the engine did not go over top dead center and so the compression pushed things backwards (that's when the sprag does its job -to protect the starter motor from backwards motion).
HTH
