Old 916 tach help needed - Ducati.ms - The Ultimate Ducati Forum
Old Jan 7th, 2012, 6:58 pm   #1 (permalink)
I took my original 1995 916 out for a ride today after a long layoff. The tach registers 0 revs at idle, and then quickly moves to 6000 revs at almost every other throttle setting. Technician's tests indicate the problem is in the tach itself. Any known fixes or leads on a good repair service? I'm in California's Central Coast, it that matters. Or if someone has a same-vintage 916 tach, that would be another option. Thanks for the help.
Sam Mancino
samancino is offline   Reply With Quote
Old Jan 7th, 2012, 7:04 pm   #2 (permalink)
Try tightening the 3 brass screws on the back of the housing. That resolved the fluctuating reading on my '95........
916WI is offline   Reply With Quote
Old Jan 7th, 2012, 10:03 pm   #3 (permalink)
velocidave's Avatar
I thought (and I could be wrong, Im three vodkas in...) that was an indicator for some Voltage problem? The tach swings from zero to 6K, then back to Zero?
I may be confusing it with my YZF750, but I will dig up my service manual and see if I am misleading you or not?
2000 996 : A bunch of XRs :
1994 Landcruiser : 2002 Discovery II (DEAD): 10 Bicycles
4 Kids : 1 Dog : 5 Cats : too many birds :
velocidave is offline   Reply With Quote
Old Jan 9th, 2012, 4:42 am   #4 (permalink)
Tach issue
If I'm correct, all the '95 916's used the P-8 computer, so any later tachs won't work as the internal circuit boards are different. I've had similar issues with mine where a solder connection was broken inside. The only way to take it apart is to get the bezel off to get to the insides.
Other than that, your left side engine cover has two sensors, a rpm/tach sensor, and a separate cam timing sensor. Check the depth gap on the tach sensor and ohm resistance to make certain it's good.
916duc is offline   Reply With Quote
Old Jan 10th, 2012, 5:59 pm   #5 (permalink)
Ducatierv's Avatar
Yes same with the SPS that use P8 , other Tachs won't work
1199 Panigale Tricolore
996RS Corse - Ben Bostrom's #155 Vance & Hines Racebike
05 1122R Ducshop stroked 999R "Big Meanie" Racebike
08 D16RR
03 999R #171
06 999R Motocorse Racebike
95 916 x 4 [Varese Bikes]
00 996SPS "Roxanne" #1418Racebike
00 996SPS Rebuild in progress
99 996SPS
98 916SPS #904
98 916SPS #640
98 748SPS RS spec NCR racebike
00 748RS
93 888SPO
99 748 with 853 kit 700miles from new
05 749S CCS Racebike
00 984R next project!
Bimota YB11 Attack Race Motor
MV Agusta F4 ORO #293
05 MV Agusta F4 1080 CCS Racebike
96 944SS extensive mods(nearly finished)
92 944 CCS Racebike rebuild in progress
88 Paso 750 Limited
90 851 SuperBike
99 996 Biposto FOR SALE
01 996 Biposto
06 749D
99 Laverda 750 Formula
Ducatierv is offline   Reply With Quote
Tach help needed - GT1000 way444 Sport Classic 2 May 1st, 2011 10:00 pm
Hello...GT1000 Tach Help Needed way444 Welcome and Introduction 1 May 1st, 2011 8:32 am
FS:DP LED Tach Düb Lüv Parts and Accessories 2 Oct 2nd, 2010 10:20 am
WTB Tach couchflyer Parts and Accessories 2 Apr 3rd, 2010 10:52 am
tach help yukio Superbikes 2 Apr 13th, 2009 1:30 am
