Half of engine is running rich - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearGraves MotorsportsMotorcycle.com Classifieds!
Old Jan 5th, 2012, 11:55 am   #1 (permalink)
Hello and Happy New Year to you all
After carefully shimming valves, setting cams and TPS, balancing etc, I find out that the horizontal cylinder is running rich and the vertical is lean by plug inspection and sooty (er) right can. What gives? Everything is bog stock ('02 998)
Help is much appreciated
Thanks for reading
Eurico
eurico is offline   Reply With Quote
Old Jan 5th, 2012, 2:15 pm   #2 (permalink)
TomTom's Avatar
Throttle bodies out of sync comes to mind.
Check everything is fix and fine, if so you need to balance (sync) them.
I just experienced an 1198 with TB nut for rear cyl loose just a bit, it ran awful on low openings.
And a huge AFR difference between cylinders, so I stopped there and found the linkage was loose, fixed that and tadaa!
On 998 also check that TB opens fully, Ive done a few and on those they didnt, not even close, if so grind the stop to fit.
Cam timing and that gave 5-7 hp all the way from 6k up, silly
TomTom is offline   Reply With Quote
Old Jan 10th, 2012, 4:09 pm   #3 (permalink)
Thanks TomTom
I will check out what you mentioned.
Eurico
Running rich? silvertdi Superbikes 2 Aug 19th, 2011 10:56 pm
Running Rich mysticbluex3 Monster 2 May 25th, 2011 3:37 pm
998 running rich FFWD Superbikes 3 Apr 22nd, 2010 10:02 am
Running rich ernie300w Supersport 3 Apr 3rd, 2009 8:58 pm
Running too rich... streetsurfer Sport Classic 21 Mar 25th, 2009 8:40 am
