Two quick questions, since I'm at work and can't look over my bike in it's terrible state of disassembly (half-way through replacing the starter):
The fuel disconnects on the 98 916 are color coded, one's black and one's white. Also, the black one is towards the front of the base plate and the white one is towards the rear. I need to know which one is the send line and which one is the return line. The white/rearward one broke on me, but the Ducati dealership can't look it up by color or position, they need to know the flow.
Also...on ca cycleworks, they listed both of these spark plugs as an "all except testastretta" fitment:
NGK D8EA
NGK DCPR8E
Anyone use either of these, or can confirm the fitment? I read somewhere that the 'R' in the second number stands for 'resistor' and is a better plug, but I want to poll the board and see what you guys think.
I'm trying to work all this into my lunch break today (swinging by a local race shop for the NGK's because the dealer wants $28 per spark plug, then to the dealer for the fuel connector, which they'll rape me on to the tune of either $78 or $58, depending on wether it's send or return. :/ Just for the record, don't listen to the Haynes when it tells you that you can disconnect and prop up the fuel tank without separating the lines. :/
Thanks guys! Hopefully my incessant questions will be done by the end of the week and I can get back on the road!
