Q: 1198SP Dashboard replacement - Ducati.ms - The Ultimate Ducati Forum
Old Jan 3rd, 2012, 6:03 am   #1 (permalink)
Vdue's Avatar
I broke my dashboard of my 1198SP on a racetrack and I am looking for a replacement. The options are:
A brand new Ducati dashboard would burn big wholes into my wallet, therefore I am looking for a used dashboard.
Can I install a used dashboard if I get the key card accompanied with it ?
If anybody can reccommend another aftermarket dashboard solution that would be appreciated as well.
Thanks in advance.
http://www.moto.dotklein.com
1198 SP '11
HYM S '08
Roughneck '07
Vdue is offline   Reply With Quote
Old Jan 3rd, 2012, 10:51 am   #2 (permalink)
Once a Dash has been "married" to an ECU the two theoretically cannot be separated; However, you may have the following options at your disposal:
1. Buy a used dash, along with its married ECU as well as the lockset that is associated with that dash and ECU and install all items on your bike. (note, at this point you'll have a dash with an incorrect odometer reading)
2. Buy a new dash, as well as a new set of locks (A new keycode card would come with the lockset) and have the new dash married to your existing ECU. (you'll once again have a dash with an incorrect odometer reading)
3. Buy a used dash and have your ECU "re-programmed" to remove the immobilizer function. (again, you'll have an incorrect odometer reading)
4. Buy a used dash and send it along with your ECU, your existing key and possibly your ECU to a company like S.O.S. Diagnostics for re-programming of the dash and extraction of the immobilizer code. (they can usually "correct" the odometer reading to match what your bike actually has in this process)
I would check with Chad at (S.O.S. Diagnostics - Automotive Programming and Diagnostics) to verify what they can do for you in this case. I recently sent the dash from my 848 to them for extraction of the immobilizer code as the previous owner lost the keycode card. They did a great job and turn around time was very quick.
I think there might be a company in the UK that offers similar services but I can't remember who they are.
Hopefully this helps and best of luck.
'08 848, Red (Termi's.. not much else needed)
'01 ST4, Blue (Arrow Pipes, Ohlins Rear Shock, Alum. Swingarm, DD Headlight, CRG Levers, CycleCat Risers)
'02 Monster 750S i.e., Senna (Remus Pipes, Rizoma Triples & Clip-ons / Belt Covers/ Mirrors/ Sprocket Cover)
ducati_750 is offline   Reply With Quote
Old Jan 4th, 2012, 3:43 am   #3 (permalink)
Vdue's Avatar
Thanks a lot for your explanation. I found a used dash and will go with this option:
1198 SP '11
HYM S '08
Roughneck '07
De-blinging the dashboard poolagent Sport Classic 23 Feb 12th, 2012 7:54 pm
What is the red flash on dashboard for? nethern HyperMotard 22 Nov 9th, 2011 8:29 pm
Dashboard Ciccio Bkk Sport Classic 18 Jan 30th, 2010 11:35 am
Finally my new dashboard...... Luca_M Superbikes 34 Oct 30th, 2009 10:21 am
DashBoard update for 748 748Rider Superbikes 1 Sep 7th, 2007 9:39 am
