quick connectors for fuel tanks - Ducati.ms - The Ultimate Ducati Forum
Old Oct 28th, 2006, 12:44 pm   #1 (permalink)
Maine748's Avatar
Question quick connectors for fuel tanks
I see these metal(better than plastic duc part) quick fuel connectors. Seems like the threaded holes in my 748 tank (in/out) are 12mm and the connectors threads are 14mm. What's up with that. Thanks Al
Maine748 is offline   Reply With Quote
Old Oct 29th, 2006, 1:10 pm   #2 (permalink)
You're not trying switch your tank over to QD's, are you?
If you are, you'll need to get a tank plate that is made for QD's. Putting QD's on a metal-line tank plate isn't a direct swap.
You can get QD tank plates off of ebay for pretty cheap.
paulo57509 is offline   Reply With Quote
Old Oct 29th, 2006, 4:55 pm   #3 (permalink)
dragknt's Avatar
Not to thread-jack, but in a related note...is there anywhere other than a dealer (like someplace online) to get the OEM quick connectors? And how much would a Duc dealer charge for them?
1998 Ducati 916
dragknt is offline   Reply With Quote
Repairing leaky rusted steel tanks Rainman Hall of Wisdom 14 Jan 6th, 2011 11:31 pm
