999R dies from time to time - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Oct 18th, 2011, 9:43 pm   #1 (permalink)
silvertdi's Avatar
My 2006 999R dies occassionally. I'll be riding around and the engine will die. I'll pull in the clutch, hit the starter, and be back under power, but it shouldn't be doing that. It has a 57mm Termignoni exhaust and DP race ECU. No other modifications. Any ideas on what could be causing this? Thanks.
silvertdi is offline   Reply With Quote
Old Oct 18th, 2011, 10:31 pm   #2 (permalink)
Smile
the next time the engine stalls don't pull in the clutch watch the tachometer
needle if it falls like a rock ... you have an ignition problem but if the tachometer stays up you have a fuel problem....
DesmoRR_16 is offline   Reply With Quote
Old Oct 18th, 2011, 10:32 pm   #3 (permalink)
rockk's Avatar
i had similar issue. it was poor connections near my battery /corroded rusted contact.
rockk is offline   Reply With Quote
Old Oct 18th, 2011, 10:36 pm   #4 (permalink)
just curious did the connection problem a part of the ignition or fuel side electrical?
Old Oct 19th, 2011, 2:27 am   #5 (permalink)
LAN
LAN's Avatar
Does it fail to start once in a while? (Push start button & nothing)
Are you saying that you're riding at say 60mph and the engine just 'dies?
_
LAN is online now   Reply With Quote
Old Oct 19th, 2011, 5:39 am   #6 (permalink)
safetyfish's Avatar
Loose connection somewhere, two likely culprits:
Side stand switch
Connection that goes into the airbox on the bottom right side of the airbox
Failing that, start looking for a loose wire that has chaved through and is earthing itself against metal somehwere
SF
999R
998 Bayliss
safetyfish is offline   Reply With Quote
Long time lurker, first time poster hideehoo Welcome and Introduction 0 May 11th, 2011 10:33 pm
Long time rider, first time Ducati owner ffnatoli Welcome and Introduction 0 May 1st, 2011 5:56 am
Long time forum reader first time poster. ezmoto Welcome and Introduction 1 Mar 14th, 2011 8:08 pm
Long Time Lurker, 1st Time Poster Josef08 Welcome and Introduction 0 Apr 3rd, 2010 5:36 pm
Dropped my 999R for the first time John Ducati Motorcycle Chat 50 Jun 21st, 2009 1:25 am
