Adding chain links? - Ducati.ms - The Ultimate Ducati Forum
Old Oct 15th, 2006, 4:14 pm   #1 (permalink)
stover's Avatar
Images: 2
Adding chain links?
I cut off my old 525 chain from my 749S and ordered a 520 kit. I have not received the kit yet. So, can anyone tell me if I will need to add links to a 520 DID EVR3 chain (120 links) if I am using a 14/43 setup on a 749S?
Thanks.
2000 Monster 900 Sie
2006 Honda RS125
stover is offline   Reply With Quote
Old Oct 15th, 2006, 4:28 pm   #2 (permalink)
galaxy's Avatar
Images: 27
A new chain should be pleny long. You'll most likely end up removing a hand full.
www.ducati-owners-group.com
galaxy is offline   Reply With Quote
Old Oct 15th, 2006, 5:06 pm   #3 (permalink)
SuperbikeSB's Avatar
Images: 10
yeah you will remove between 6-8 entire links. a 43 t huh? that's pretty high but i think you'll like it. i was running 14/42 and i caught a few people off guard when coming out of corners at the track, it accelerated really fast.
2003 749s
2006 749s
2008 1098s
Ciao, Marco. You are in our hearts.
SuperbikeSB is offline   Reply With Quote
Old Oct 15th, 2006, 5:57 pm   #4 (permalink)
stover's Avatar
Images: 2
Yep. I have been told a 14/42 or 14/43 is a nice setup for Buttonwillow. Last week I ran the course both CW and CCW with the stock gearing 14/38 and I could bearly get out of my own way. I may pick up a 41 and 42 also for Thunderhill. Which track did you run your 749 at?
2006 Honda RS125
Old Oct 15th, 2006, 7:17 pm   #5 (permalink)
Images: 10
i ran at blackhawk farms in IL. Its a pretty tight track with fairly short straights so the gearing was nice. I don't know about Buttonwillow but i have been around Thill and a 41-43 should be fine there, i would prefer a 41 or 42 due to the staights. it sounds like you are well on your way to being even happier with your Ducati. make sure to let us know how it goes and post some pics to show off your hard work (and maybe help someone else thinking about making the switch.)
2003 749s
2006 749s
2008 1098s
Old Oct 15th, 2006, 11:42 pm   #6 (permalink)
Just did the DID 520 convertion on my 999 and had lots of links left over...
g4go is offline   Reply With Quote
Chain and Rear Sprocket Question Gallep Superbikes 8 Aug 7th, 2007 9:53 pm
Chains 101 nathanTX Hall of Wisdom 3 May 17th, 2007 5:41 pm
Chain Making Bad Sounds Stang65 Supersport 23 Oct 6th, 2006 7:13 am
HELP!! Chain tightening zer0 Superbikes 14 Aug 26th, 2006 4:12 am
New Sprocket and Chain Tension 03/04 749 red_ryder Superbikes 2 Mar 28th, 2006 12:03 am
