Oct 7th, 2006, 9:50 pm
Need high quality chain grease
Please help me...... I bought what I thought was a high quality chain grease, 'Shell Advance Chain - High Adhesion'. Only every time i go riding, it all flicks off onto my back rim and under my exhaust. I spend around 1 hour after every ride cleaning it. I apply the grease after a ride when the chain is warm, as directed. If anyone knows of a better grease that actually sticks to the chain, I would appreciate your help.
Thanks
999s ex-owner, Monster owner wannabe
"Those who criticize this generation forget who raised it"
Oct 7th, 2006, 10:11 pm
Maxima Chain Wax. I guarantee it will not sling off...not even a little bit. Clean your chain really really good before applying. This is a wax and designed to basically seal the chain by coating it and protecting it.
www.ducati-owners-group.com
Oct 7th, 2006, 10:42 pm
Thanks. Exactly what i need, something that'll stay on the chain - I'll look out for it. Hopefully they sell it here in Aust.
Oct 8th, 2006, 3:01 am
Do you let it sit and dry for half an hour before you go ride? I wipe off any excess to and usually dont have much of a problem. At least not an hours worth of clean up.
Oct 8th, 2006, 5:32 am
Keep the Shell stuff... just use it as a chain cleaner. Spray it on a rag and wipe the chain down link by link. Then get the good stuff and lube it.
I use Maxima, so it IS in OZ, but prefferd the white Silkolene stuff. I just couldn't find it last time. I think Bel Ray does a good one in a mini can you can stuff under your seat.
Mal
I only lack THREE things to be a GP rider....
Talent, Ambition and Initiative
"Ergost yellicium mosticom finae speddicullus maximisan. Despitate ducati ergoni matchello"
Oct 8th, 2006, 11:15 am
Bel-Ray chain wax (presume Maxima is about the same). The key is you have to apply AFTER you ride, when the chain is warm. procedure is
- return from ride
- put bike on rear stand
- start bike and put in 1st gear,
- generously apply, let bike run for 1-2 minutes on the stand to distribute lube.
- park
It will be perfectly lubed, and won't fling once. This is what we use on our racebikes.
Oct 8th, 2006, 1:21 pm
+1 for the Maxima wax
"There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games." - Ernest Hemingway
You wouldn't trust old rubber humping a strange girl, don't trust old rubber tearing up the twisties. Buy new tires.
'09 MTS 1100S
'04 999S -sold
'99 900SS -sold
'94 900SS -sold
