1996 916sp info? - Ducati.ms - The Ultimate Ducati Forum
Old Sep 24th, 2006, 8:59 am   #1 (permalink)
1996 916sp info?
could some please give me some info on the 96 916sp, I been looking and can`t find much like what`s diff over the regular model and also only thing
I found is that this model has a 955cc engine? is this correct?
hori is offline   Reply With Quote
Old Sep 24th, 2006, 11:34 am   #2 (permalink)
JEC
JEC's Avatar
According to Haynes:
Different cylinder head
Bigger valves
Raised compression ratio
Ti connecting rods
Uprated clutch assembly
P8 Weber-Marelli system with dual fuel injectors per cylinder (Strada has one per cylinder)
22hp over Strada
Ohlin's shock
Cast iron brake rotors
Braided steel brake lines
Carbon fibre silencers
Carbon fibre body panels
There is no mention of a 955cc displacement; later SPS models were 996cc, but according to the manual the SP was still a 916cc.
'97 916
MBP collets, Surflex clutch, 996 rotors, FBF slip ons, Senna EPROM, SPS mono tail, SPS carbon-fibre undertray, Corbin seat, black powder coated frames-wheels-swingarm, Ohlins shock
'84 Honda VF750F Interceptor (gone)
'04 Suzuki SV650 (gone)
'87 Honda VFR400R NC24 (gone)
'85 BMW K100RS (gone)
JEC is offline   Reply With Quote
Old Sep 24th, 2006, 11:37 am   #3 (permalink)
thanks for info JEC, 22hp over strada, seems like alot. What would the hp be then same as 996?
Old Sep 24th, 2006, 11:41 am   #4 (permalink)
JEC
JEC's Avatar
HP numbers for those Ducs are notoriously unreliable, but this is what the manual states:
916 Strada 97hp
916 SPS (996) 124hp
996 Biposto 113hp
996 SPS 123hp
I would venture a guess that it would be around 110-115 at the wheel for the SP. If anyone knows better please correct me.
'97 916
Old Sep 24th, 2006, 1:54 pm   #5 (permalink)
cachee0's Avatar
916 Strada 97hp
916 SPS (996) 124hp
996 Biposto 113hp
996 SPS 123hp
Ya the claims are off my 748 is 97 and my 916 is 105 yet the 916 is stupid fast compared to the 748. Less then a 10hp I don't think so. I bet the Ducati tech just guess basied on what number suits their liking.
Don’t worry about the laws of physics, it will come fine you.
Now
2005 749S (Coming Soon)
Past
2000 748 BI
1998 916 Mono
2006 CBR600RR
cachee0 is offline   Reply With Quote
Old Sep 24th, 2006, 6:39 pm   #6 (permalink)
Ducati made a limited number (54) of a model designated 916 SPA (Sport Production America) in 1996. It was made to homologate the 955cc motor for AMA Superbike racing and thus displaced 955cc.
Even though Ducati brought 50 into the USA, many were sent to other countries after the homologation requirement was met.
Brian
Motobee is offline   Reply With Quote
Old Sep 24th, 2006, 7:46 pm   #7 (permalink)
JEC
JEC's Avatar
A more accurate comparison would be the original claim of 114hp for the 916... 105 was a later claim, and is closer to the rear wheel HP but lower than the crank power. 97 is the peak crank hp of the 748.
Generally a stock 748 will put out between 80-90 at the rear wheel, a 916 95-105. The 748 isn't that far off in power, but it also revs higher (and flakes the rocker arms more easily) and has less midrange which makes it feel a lot less powerful than the 916.
'97 916
916 Senna VS 916SP (955) badass916sp Superbikes 13 Mar 9th, 2009 9:29 pm
Found a ST info site... Wombat Sport Touring 1 Jun 24th, 2006 3:26 pm
Forking Ideas for a 1996 900CR nomadwarmachine Supersport 13 May 24th, 2006 3:56 pm
