999 Headlight Fuse Help - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Motorcycle.com Classifieds!
Old Apr 2nd, 2011, 6:27 pm   #1 (permalink)
So installed my HID lights and the license plate relocator. All lights were working. Get home with the bike and now the headlights dont work, but the high beam passer switch works as the highs flash. The left turn signal is also out. Since I dont have the manual, can somebody point me in the direction that the light fuses are located for the bike.
Glowfinger is offline   Reply With Quote
Old Apr 2nd, 2011, 7:27 pm   #2 (permalink)
spf_970's Avatar
Pages from owners manual. Hope it helps
2006 Harley Street Glide
2007 1098S Tri
2008 MV Agusta F4312R
2009 1198S Dedicated Track Bike
spf_970 is offline   Reply With Quote
Old Apr 2nd, 2011, 8:02 pm   #3 (permalink)
Thanks, so I thought thats where they should be and there was nothing in there.
So I see a few wires going into some electrical tape. Undo the tape and behold the previous owner electrical taped the wires to the fuse directly. So now I need to make a fuse box to do this correctly. Off to auto zone..ugg
Old Apr 3rd, 2011, 3:26 pm   #4 (permalink)
Sounds like it was used as a track bike at one time. You might want to open things up and see if that mindless asshole screwed up any other wiring before you trust it on the street.
'09 Kaw Versys
'00 Kaw KLR650
USN Vet.
ttpete is offline   Reply With Quote
Old Apr 4th, 2011, 8:51 pm   #5 (permalink)
So I fixed the fuses and I effed up. Didnt disconect the battery before I started and one hot wire sparked against the fuse access on the headlight cover. Get everything together and I turn the key to on and NOTHING. I checked all fuses and continuity and all checks out. The battery has volts, all fuses work, wish I had the wiring diagram. That wouldnt short out the ECU from the front fuse would it?
Any advise would help at this point. I really dont want to pay the dealer labor cost to chase this down.
Old Apr 4th, 2011, 9:11 pm   #6 (permalink)
spf_970's Avatar
Did you check the two fuses down adjacent to the battery? One of those protects the ECU.
2007 1098S Tri
Old Apr 4th, 2011, 10:03 pm   #7 (permalink)
Ya I checked them and they were fine. Would it have shorted the spedometer of or whatever its called?
Hyper Carbon Nose, Headlight & Headlight Bracket Petree Dish Parts and Accessories 2 Jan 28th, 2010 1:01 am
999 Headlight Fuse ? fyodordos Superbikes 3 May 11th, 2008 10:14 pm
Headlight fuse keeps blowing - 998 odrides Superbikes 5 Feb 20th, 2008 7:37 am
ST4 Headlight fuse MarkST Sport Touring 2 Jun 4th, 2007 3:45 am
Which fuse for the 749 headlight? kurtfriedrich Superbikes 4 Apr 19th, 2007 4:47 pm
