Cush Drive replacement... when damaged only or upon milage? - Ducati.ms - The Ultimate Ducati Forum
Old Sep 12th, 2006, 5:19 pm   #1 (permalink)
desmofetish's Avatar
Hey guys, I am curious... I have 20k on my 2001 748. With no known signs of cush drive wear, is there any reason I should replace them when swapping my chain and sprocket?
(a) Does Ducati note the estimated life (milage) of the stock cush drives?
I will have a AFAM quick change sprocket carrier installed so, due to the cush drive "tabs", I am not concerned about them backing out.
(b) Any specific signs one should look for to determine their condition?
Thanks....
Thomas Lowers
2001 748 Superbike
Charcoal Grey with Carbon highlights and Red wheels
Full Termi Exh,Surflex Slipper,GP Master Brake,GP Mater Clutch,Evo Slave,Ultimap Chip,ITG Filter,AFAM Quick change and gearing...Carbon Nose w/enlarged ports,Carbon Airbox & Runners,Carbon Mono-Tail/Custom Bi-posto Tail, Speedymoto Triple Clamp,Tec Moto Clutch Cover,L.E.D. Taillight,Custom painting...= Empty Wallet,Hungry Cat & Unfurnished Home...Thank God I'm Single!
http://www.ducati-owners-group.com/
desmofetish is offline   Reply With Quote
Old Sep 12th, 2006, 6:05 pm   #3 (permalink)
DukeDesmo's Avatar
Images: 144
I had to fit a new sprocket carrier assembly last year at around 18,000 miles (due to the ciclip wearing away the carrier and grinding the swingarm) and although I did fit new cushdrives, the old ones looked fine. So I would change them only when they are cracked or loose.
916 & M944 'project'.
DukeDesmo is offline   Reply With Quote
Cush Drive Bushing Replacement? RichD Supersport 15 May 3rd, 2010 12:36 am
cush drive removal Herbivator Superbikes 8 Aug 21st, 2006 2:56 pm
