848 battery cable and 30 amp fuse? - Ducati.ms - The Ultimate Ducati Forum
Old Jan 16th, 2011, 6:25 pm   #1 (permalink)
horwitzs's Avatar
Got an upgraded battery cable kit.
The stock positive cable has two wires coming from the terminal, one of which goes to the 30 amp fuse right next to the battery box.
The replacement positive cable is a single lead, with no provisions for the fuse (see photo).
Hmm... Cut off the line to the fuse and crimp a new ring-connector on?
-Seth; 848, SV650S, 250 Ninjette.
Life is tough. It's tougher if you're stupid.
horwitzs is offline   Reply With Quote
Old Jan 16th, 2011, 6:37 pm   #2 (permalink)
Yep, gotta have the fuse else melt-down-city if the regulator fries, which they often do.
pjonte is offline   Reply With Quote
Old Jan 16th, 2011, 8:26 pm   #3 (permalink)
Italkart21's Avatar
Images: 37
The new cables just piggyback the stock ones. Do not cut anything
Italkart21 is offline   Reply With Quote
Old Jan 16th, 2011, 8:49 pm   #4 (permalink)
ELK
If this is the Motoelectric kit, their website has instructions posted with a large amount of pictures.
ELK is offline   Reply With Quote
Old Jan 16th, 2011, 9:11 pm   #5 (permalink)
I had the same issue when I installed the Motolectic kit. You will completely replace the cable from the solenoid to the starter motor. However, you will need to retain the stock postive & negative battery cables. For the positive side (red side) first place the stock cable on the bettery & then the motolectric cable on top of it. However on the solenoid side, you will first place the motolectric cable directly to the terminal & then the stock cable on the top of it. You will want to do the same for the negative battery cable as well (black side)
arshishb is offline   Reply With Quote
Old Jan 17th, 2011, 11:29 am   #6 (permalink)
horwitzs's Avatar
I'll look again, I must have missed them last night.
Thanks for the tips everyone.
Old Jan 17th, 2011, 3:45 pm   #7 (permalink)
ELK
Clicky
Battery Cable upgrade mry999eryk Superbikes 161 Jul 17th, 2011 7:15 am
positive battery cable melting! roverclassic Superbikes 13 Jan 20th, 2010 9:19 pm
routing the battery tender cable zvez StreetFighter 11 Jun 24th, 2009 5:54 pm
HELP - Battery Cable Routing quikduk Supersport 0 Feb 11th, 2008 1:14 am
Battery Cable Failure Xannadu Sport Classic 8 Apr 1st, 2007 3:20 pm
