UM222 chip & carrier - Ducati.ms - The Ultimate Ducati Forum
Old Sep 11th, 2006, 12:26 am   #1 (permalink)
I just purchased a UM222 chip for my '99 996. When it arrived, the chip was separated from the carrier. What is the proper orientation of the chip to the carrier? It seems that the chip can go into the carrier either way. I understand that the chip, once installed in the carrier is installed with the notch in the chip closest to the housing of the ECU, just like the original chip.
Thanks
tshp6576 is offline   Reply With Quote
Old Sep 11th, 2006, 12:49 am   #2 (permalink)
Desmo93's Avatar
This is based on the picture provided in the installation instructions for the chip. Looking at the ECU so that the cable connections are on the left, the notch on the board will orient towards the cable connections and the chip will plug into the board so that the writing on the chip is right side up (i.e readable, not upside down). If needed, I can try to scan the instructions.
93 900 SS
01 996 Mono
00 ZXR 400 SP
06 Daytona 675
Desmo93 is offline   Reply With Quote
to chip or not to chip... pdittay Superbikes 3 Aug 23rd, 2006 9:21 am
Aftermarket chip for 748 Superbike...any suggestions? desmofetish Superbikes 2 Aug 16th, 2006 12:38 pm
996/916 chip mod jt1921 Superbikes 7 Jun 30th, 2006 12:16 am
AFAM Carrier...$62.96????? Tat2Skullz Superbikes 2 May 4th, 2006 10:10 pm
