Sep 10th, 2006, 2:14 pm
exhaust sealant
at every juncture/slip in area? (748) on my exhaust, from the headers back i have exhaust leaks and i want them gone. I've done the Bondo exhaust filler/selant, some off brand exhaust leak stopper, and even JB welded it. regarding JB weld, it melts like a freak and stinks like a dead animal.
i've thought about exhaust wrap but am to lazy to order it. anyone have any ideas on how to stop the problem, as in what do you use?
thanks regardless.
the manual life of an animal
Sep 10th, 2006, 2:39 pm
When I helped install my friend exhaust on his 04 999, it did the same thing but only with the small vertical header. We tried everything and nothing worked because it gets so hot that it melts everything. We even welded the pipes too lol, but he eventually got a full system and fixed the problem.
My 05 999s came with a slip on and it had small leaks from the slip on and the small vertical cylinder header, but it goes away once the pipes are hot. I guess it expands or something. Ducati's seal are too thin/small and it does not seal correctly. I've heard of some people installing a two DP exhaust seals instead of one and it fixes the problem. The only issue about the two exhaust seals is that it is a pain in the behind to install the pipes together.
If you do not understand my silence, you will not understand my words.
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
Martin Luther King Jr
05 999s (She's gone  )
05 K5
Sep 10th, 2006, 3:08 pm
I used permatex copper RTV silicone with considerable success. It's bright orange in color so just make sure you cleanup any excess from the outside, unless you like that look.
http://www.permatex.com/products/aut...sket_Maker.htm
Oh yeah,...you can get it at most advance autoparts stores.
Sep 10th, 2006, 3:13 pm
Banned
Oh yeah,...you can't get it at most advance autoparts stores.
+1 I used the same stuff works good.
Sep 10th, 2006, 8:52 pm
Used it on my friends bike. After a 12 hr ride it was still leaking lol.
05 K5
Sep 10th, 2006, 9:01 pm
Are you guys letting the permetex sealant dry for at least 4-8 hours?
Ducati 998 Matrix Reloaded (2004) - 45/50mm CF Termignoni, gold Cyclecat clutch cover/pressure plate
http://www.motocorsaitaliano.com - Ducati Maintenance Service Kits (Maxima, Mobil1), Spark Plug Kits and Coolant kits and DMS.
Sep 11th, 2006, 9:06 am
I used a bandaid type of sealant, that drys with heat. Didn't like it. I think I 'm going to get some high temp silicon.
Sep 11th, 2006, 11:15 am
Ducati.MS sponsor
Take the pipes to a good muffler shop and have them expand the fittings slightly to get a tighter fit.
Before you go: mark each fitting carefully and mark areas where it is leaking so they know what joints need the most attention.
Use the Permatex when putting it together (that stuff is only good for small gaps).
Oct 5th, 2006, 6:29 am
Just saw this as a link to from another thread.
Best for me in this instance is, as mentioned above, high temp silicone. Just use Loctite grey silicone. It doesn't move, harden, burn and stays pliable. Excess wipes right off. I use it right at the head/header connection and everywhere else and it's stable as anything.
Oct 5th, 2006, 10:02 am
Permatex Motoseal Ultimate Gasket Maker Grey. It's designed for this sort of application. Apply it liberally to both halves, put it together, wipe off the excess and let it dry a little while. It cures when the exhaust heats up.
'97 916
MBP collets, Surflex clutch, 996 rotors, FBF slip ons, Senna EPROM, SPS mono tail, SPS carbon-fibre undertray, Corbin seat, black powder coated frames-wheels-swingarm, Ohlins shock
'84 Honda VF750F Interceptor (gone)
'04 Suzuki SV650 (gone)
'87 Honda VFR400R NC24 (gone)
'85 BMW K100RS (gone)
