2010 Multistrada news:"11 degree" 1198 motor - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.com
Motorcycle.com
Old Nov 1st, 2009, 6:33 pm   #1 (permalink)
Extended Member
CAlexio's Avatar
Just found some news on the italian sites that the engine for the new multistrada is indeed from the 1198, but will be more progressive: codenamed "testastretta 11 gradi"... (means 11 degrees). Any guesses to what that refers to?
EDIT: also I am officially creating a party in opposition to that created by whippersnapper, in my declaration that the beak WILL be there... (you can see it in the movie for a split second ) :-)
http://multistrada.ducati.com/
Old Nov 1st, 2009, 7:39 pm   #2 (permalink)
whippersnapper's Avatar
It's definitely there, I just hope it unbolts!
______________________________________________
Ducati News, Reviews and Opinion ducatinewstoday.com or Tweet me @ducatinewstoday or Like Me on Facebook
whippersnapper is online now   Reply With Quote
Old Nov 1st, 2009, 9:00 pm   #3 (permalink)
Extended Member
CAlexio's Avatar
so what does the 11 degrees stand for do you think? something with timing so as to make engine smoother? A flatter torque curve which has an 11 degree angle? (I'm stretching here).
Old Nov 1st, 2009, 9:30 pm   #4 (permalink)
ST & SC Junkie
SE84's Avatar
Images: 2
It might mean that the head is now narrower than the normal Testastretta.
The DesmoQuattro included valve angle is 40 degrees, and the Testa 25. Maybe they have compacted the head to where they don't need a camshaft any more.
A SOHC 4-valve maybe?
j/k
Current pastimes:
2007 Sport 1000 SE #84
2004 ST4s
SE84 is offline   Reply With Quote
Old Nov 2nd, 2009, 6:54 am   #5 (permalink)
bite me
thelumox's Avatar
maybe each pair of valves are set 11 degrees from the bore line. so the total included valve angle would be 22 degrees...........
Casey
'07 Monster S4RS black
'10 Multistrada 1200 red
'12 Monster 696 ABS red
thelumox is offline   Reply With Quote
Old Nov 2nd, 2009, 7:09 am   #6 (permalink)
Extended Member
CAlexio's Avatar
ok... this seems to be the most plausible to this point. hmm...
Old Nov 2nd, 2009, 8:15 am   #7 (permalink)
Moderator
stryder's Avatar
j/k
Or a SOHC 6v.
Regards,
Frank, '05 ST3, (Red!!)
"Veni, Vidi,....Ducati!!"
Old Nov 2nd, 2009, 10:21 am   #8 (permalink)
theduckllr's Avatar
Or the engine is designed to be run at 11F optimal temperature (in a dramatic bid to dominate bike sales in the Artic)
No, I'm not a Gynecologist, but I did stay at a Holiday Inn Express last night.
theduckllr is offline   Reply With Quote
Old Nov 2nd, 2009, 10:39 am   #9 (permalink)
My guess it is something to do with the cam timing change to get a much better bottom end power delivery
Old Nov 2nd, 2009, 11:05 am   #10 (permalink)
Motard-Menace's Avatar
Maybe its something they pulled out of thin air and it has no meaning. They just wanted to have something for forum members to speculate for the last week prior to unveiling......
MOTARD-MENACE
07 BMW F800S
Motard-Menace is online now   Reply With Quote
New Multistrada for 2010 amullo Multistrada 142 Sep 4th, 2009 2:17 pm
"Official" computer-generated image of 2010 Multistrada replacement: PhilipMSPT Multistrada 27 May 18th, 2009 7:51 pm
2010 Multistrada replacement = Strada Aperta? PhilipMSPT Multistrada 29 Jan 11th, 2009 3:48 pm
new Ducati motor by 2010 mojodog Ducati Motorcycle Chat 22 Sep 6th, 2008 10:17 am
Multistrada 1100 motor in sport classic? Kmart Sport Classic 3 Dec 20th, 2007 12:50 pm
