Bluetooth Earbuds - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By accelerating
  • 1 Post By RACER_X
  • 1 Post By fubar929
  • 1 Post By NorCalStrada
post #1 of 10 (permalink) Old May 17th, 2017, 6:13 am Thread Starter
Bluetooth Earbuds
Has anyone had any luck with any bluetooth earbuds ?,
I noticed there is a new one to try https://www.bragi.com/thedashpro/
I have been trying to find one that will fit under a helmet, block out the wind noise and sound good
2017 Ducati Multistrada S Touring (Grey)
2011 Ducati Multistrada S Touring (Red)-sold
snap25 is offline
post #2 of 10 (permalink) Old May 17th, 2017, 9:08 am
accelerating's Avatar
If you're willing to use a wired set connected to a bluetooth receiver, I recommend sure 215s. I use the mpow receiver, which can simultaneously pair to two devices - for me phone and zumo, which makes it possible to hear directions and control spotify etc playlists on my phone via the zumo.
forsythem likes this.
'16 Multistrada
accelerating is offline
post #3 of 10 (permalink) Old May 17th, 2017, 9:12 am
Im using plugfones
I found must buds did not reduce wind noise
aschemkes likes this.
2015 Monster 1200S
RACER_X is offline
post #4 of 10 (permalink) Old May 17th, 2017, 10:16 am
I've been using Bose QuietComfort 20 noise-cancelling earbuds connected to a cheap Anker bluetooth receiver. Like RACER_X, I've also found that normal earbuds don't reduce wind noise much. The Bose QuietComfort earbuds work very well in this regard, though they do "pop" occasionally. I haven't been able to figure out what causes the popping, though it does seem to occur more often at high speeds in windy conditions.
As far as normal earbuds go, Etymotic MC5 earbuds seemed to be the best at blocking wind noise but they're no better than cheap ear plugs and stick out of my ear enough that they become uncomfortable after a couple of hours. I've tried a few other inexpensive noise-isolating earbuds and they were all terrible as far as helping with wind noise. At this point, I'm pretty convinced that active noise cancellation is the only thing likely to work better than cheap foam earplugs...
fubar929 is offline
post #5 of 10 (permalink) Old May 17th, 2017, 12:49 pm
Lifetime Premium
sfoster's Avatar
+1 for the Bose noise cancelling earbuds. They work great. The popping is not nearly as annoying or tiring as wind noise even with earplugs.
2015 DVT 1200S IBA#42277
SOLD - F800GS, K1600GTL, S1000RR, R1200GSA, K1300GT
sfoster is online now
post #6 of 10 (permalink) Old May 17th, 2017, 9:16 pm
forsythem's Avatar
Another vote for the Shure SE215 earbuds, if you go the wired route. The foam tips, not the silicone ones, isolate wind noise brilliantly - and the shape sits inside the ear and doesn't get caught taking the helmet on and off. I've used heaps of buds over the years, and these are the best fit and noise reduction.
_____________
Black 2010 848 Superbike.
forsythem is offline
post #7 of 10 (permalink) Old May 17th, 2017, 9:30 pm
Sorry, not buying anything that is aimed at guys with man-buns.
alliswell is offline
post #8 of 10 (permalink) Old May 17th, 2017, 10:00 pm
ray916mn's Avatar
I use ear buds with a BT receiver. Just broke my 3rd pair of Etymotic ER6i buds, which are unfortunately no longer produced and sell used when you can find them for 2.5 times what they sold for new. Now using custom mold plugs. Have 2 Sony Ericsson BT receivers as their 8 hour battery life is sometimes not quite enough for a day of riding. I installed a Sena 10R setup over the winter and have failed to find speakers that can play loudly enough to provide acceptable sound through foam ear plugs or musician pass through limiting ear plugs. The Sena 10R can be used with regular ear plugs with an adapter cable, but I prefer the ear buds be connected to something in my pocket than to my helmet.
The BT plugs the OP linked to don't look worth it. Battery life is too short (6 hours) and the controls on the outsides of the plugs will likely be activated by helmet pressure while wearing or while putting a helmet on. Both the Sena and Sony Ericsson receivers integrate and prioritize FLAC audio from my cellphone and GPS instruction from my Zumo 660. Unclear that the plugs linked will handle more than a single BT device at a time.
ray916mn is offline
post #9 of 10 (permalink) Old May 17th, 2017, 10:19 pm
Another Bose quiet comfort user, they work so well that I have to use the tachometer to let the clutch out with a full MIVV system and no db killer! Also getting the pop
d duc is offline
post #10 of 10 (permalink) Old May 18th, 2017, 8:55 pm
I hear (pun intended) good things about the Sure.
I've been running Westone Pro 10's https://www.amazon.com/Westone-Pro10.../dp/B00EXN4GK0 for a few years now. I selected them because I wanted good (not great) attenuation, they offer -28db. The good old yellow EAR foam plugs are -32bd, so virtually everything is blocked. -28 allows sufficient sound in, while vastly attenuating the wind noise and the music sounds terrific. I've bought new foam pieces for them and had to replace the cord once- probably have >80k miles on them.
NorCalStrada is offline
Human Verification
Any 15-17 Model Year Bluetooth Issues? rambler358 Multistrada 40 Apr 23rd, 2017 3:43 pm
Nexx Intercom X-COM Bluetooth Device moto Motowheels 0 Apr 14th, 2017 4:18 pm
Ducati DVT MTS Bluetooth and Multimedia system (2015 DVT) Jewcati Multistrada 101 Mar 13th, 2017 8:12 am
Bluetooth icon / settings gone. Amit Rana Multistrada 2 Oct 12th, 2016 3:32 pm
Wiring in Bluetooth ODBII Adapter brettski Sport Touring 0 Jul 1st, 2016 3:32 pm
