New 2017 with Problems - Ducati.ms - The Ultimate Ducati Forum
post #1 of 11 (permalink) Old May 15th, 2017, 12:55 pm Thread Starter
Hello all.
New to this forum as I just took delivery a couple weeks ago of a new Volcano Gray 2017 S Touring/Urban full Termi. I greatly appreciate all of you that have taken time to write of your problems and resolutions as it has made customizing this thing much easier. I do have a couple questions:
1. The key fob isn't working at any distance. If I hold it right up by the transponder in the right fairing, it will work. The dealer (Harrison Eurosports) in Salt Lake City, has said they don't know what to do and are sending the key back to Ducati for repair. I have read multiple key fob posts on this site and I am aware of the reset button on my current key fob. Given that doesn't work, has anyone found a solution I should let my dealer know?
2. Does anyone know if Givi top cases will work on the mounts provided for the Ducati top case in the Urban package? Based on the mechanism, I'd say the Ducati case is made by Givi. But I bought a Givi E370 Monolock case to have a smaller option thinking it would be interchangeable. But it used a completely different locking mechanism. Is there any kind of Givi mount that is the same as the Ducati top case mount?
3. Is there a commonly accepted footpeg that is a little wider than the standard Ducati? My foot is a little wide for the right side peg.
4. Is there a commonly accepted way to get maximum handlebar height and pullback (I'm 6'4" with short arms for my height)? I have read posts about handlebars, Ducati risers, and Rox Risers. It appears Rox Risers are most commonly used to get maximum height/pullback without new cables. True?
Any other common things to watch out for on a new Ducati? I've read a lot of posts on wind management. Unlike most, I like having my head in clean air. I'm still looking for the right windshield height but I sure appreciate all of you who have posted (including videos) on this topic. Thank you.
And thanks all,
Ty
Tyton is offline
post #2 of 11 (permalink) Old May 15th, 2017, 5:08 pm
Bonaventure's Avatar
Welcome to the forum !!
You actually only have one problem so to speak and that's the key fob range. #2 - 4 are personal desires not related to any defect or quality issue.
2016 Multistrada S (totaled)
2013 Multistrada S Touring (sold)
Bonaventure is offline
post #3 of 11 (permalink) Old May 15th, 2017, 5:24 pm
mwhite5471's Avatar
#1 tried a new battery?
mwhite5471 is offline
post #4 of 11 (permalink) Old May 15th, 2017, 5:43 pm
Lifetime Premium
sfoster's Avatar
Regarding item 4, I noticed that the 2017 DVT Enduro has a factory riser installed (P/N 7131B801AA) source Ducati Omaha. Perhaps you could use the Enduro parts to achieve your goal?
I've used Rox risers many times and have been happy with their products. I installed the risers on my 2015 DVT and have not needed to modify the brake line.
2015 DVT 1200S IBA#42277
SOLD - F800GS, K1600GTL, S1000RR, R1200GSA, K1300GT
sfoster is online now
post #5 of 11 (permalink) Old May 15th, 2017, 5:53 pm
That's the symptom I have when the battery's on the way out.
porkrind is offline
post #6 of 11 (permalink) Old May 15th, 2017, 10:01 pm
Oaths's Avatar
#2. yes the bracket come with urban kit is using GIVI mono lock. You can use other GIVI topbox with monolock system to mount on the bracket.
You can purchase only the bracket kit and get your topbox separately
#3. Im using ducati performance handlebar riser (20mm). It's easy to fit and no need to extend the stock cables.
The enduro handlebar riser doesn't fit the standard MTS if I remember correctly.
#4. You can get MTS Enduro footpeg, it can fit and provide much bigger footprint area.
Oaths is offline
post #7 of 11 (permalink) Old May 16th, 2017, 12:35 pm Thread Starter
Thank you all. I should not have titled it problems as I was clearly looking for advice. Sorry for my error and thank you for the advice. I will try the battery, risers, and enduro footpegs. I will also try the Givi Monolock.
Thanks again,
Ty
Tyton is offline
post #8 of 11 (permalink) Old May 16th, 2017, 3:28 pm
Lifetime Premium
sfoster's Avatar
Like these from Touratech? $50 here.
post #9 of 11 (permalink) Old May 16th, 2017, 8:45 pm
Oaths's Avatar
Yes, the ones at the bottom of handlebar clamp
Oaths is offline
post #10 of 11 (permalink) Old May 16th, 2017, 11:41 pm
Givi makes two kinds of mounts and associated luggage: Monokey and Monolock. You want Monokey, which is the heavier-duty stuff commonly used on motorcycles. Monolock is for lighter-duty applications (think: scooters).
fubar929 is offline
Human Verification
2017 Airbox Lid neulee Multistrada 45 Yesterday 11:25 pm
Ignitech problems scausa Tech Forum 3 Jan 27th, 2017 5:25 am
848 - Intermittent Indicator/Dash Problems tall_man Superbikes 1 Jan 20th, 2017 3:00 am
2017? Dvt cmorgado Multistrada 27 Jul 14th, 2016 8:36 pm
Help needed, BBS & DTC problems dordiavel Tech Forum 0 Jul 12th, 2016 3:11 am
