valve adjustment range - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By mlukason
post #1 of 7 (permalink) Old Apr 16th, 2017, 6:43 pm Thread Starter
dansz24's Avatar
I am doing the valve adjustment on my 2010 multistrada 1200. all my valve clearances are at the low end but still in the MFG's suggested range. Just curious if anyone would recommend making adjustments to get to a certain clearance? should i shoot for the high end for the opener clearance and the low end for the closer clearance?
Opener range is .10-.25mm i am at the .15mm range on all the openers.
Closer range is .05-.15mm and i am in the .10mm range for the closers.
thanks in advance.
2010 MTS1200s touring
2009 MTS1100s
dansz24 is online now
post #2 of 7 (permalink) Old Apr 16th, 2017, 7:57 pm
Moderator in moderation
mlukason's Avatar
If it were me...I'd say great! close up the covers and have a beer.
Wolverine1 likes this.
Mike
2006 ST3 - 2004 KLR 650 (the Truck)
NEDOC
mlukason is offline
post #3 of 7 (permalink) Old Apr 16th, 2017, 8:16 pm
Buhgaboo's Avatar
To get the most time between adjustments bring the closers closer to .05. . . openers are good
Buhgaboo is offline
post #4 of 7 (permalink) Old Apr 17th, 2017, 11:49 am
thanks in advance.
Where are you ate mileage wise and have you checked and adjusted before. Just wonder as I picked up a 2010 last fall with 9000 miles.
mr.wesg is offline
post #5 of 7 (permalink) Old Apr 17th, 2017, 11:51 am Thread Starter
dansz24's Avatar
I'm at 14500 and I haven't checked it before.
Sent from my SM-G935V using Tapatalk
2009 MTS1100s
post #6 of 7 (permalink) Old Apr 17th, 2017, 6:05 pm
Steve W.'s Avatar
Did you replace the belts during your valve adjustment?
Cheers
Steve W. is offline
post #7 of 7 (permalink) Old Apr 17th, 2017, 8:51 pm Thread Starter
dansz24's Avatar
New belts with the valve adjustment.
2009 MTS1100s
Human Verification
2 Valve adjustment not like the Ducaticech video lemmingstab Supersport 25 Jan 28th, 2017 8:51 am
Question on 1999 ST2 Valve Adjustment gthorpe Tech Forum 5 Dec 29th, 2016 12:34 pm
Half way through first valve adjustment! brettski Sport Touring 11 Apr 27th, 2016 8:46 pm
My Experience-996 1st Valve Clearance Check Micah.Berry Superbikes 2 Jan 9th, 2016 5:27 pm
Valve adjustment on a 999R - do you remove the radiator? draganc Superbikes 13 Dec 24th, 2015 11:05 pm
