DVT Front rotor replacements (and pads) - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 25 (permalink) Old Apr 11th, 2017, 7:16 pm Thread Starter
Snowshoe's Avatar
Originally Posted by Snowshoe View Post
I ended up going with 320mm Ductile iron rotors. Search for BTD-32.R. I have not installed them yet, but will provide my impressions when I do.
Forgot to mention the Motowheels website states "special order 4-6 weeks", but when I ordered them from Motowheels they called Braketech. Braketech had them in stock and I had them in less than a week.
Present – 2015 Ducati Multistrada 1200s | 2000 Ducati MH900e **Past Sins – 2007 MG Griso|2004 Aprilia Tuono|2003 Ducati 748|2000 Cagiva Gran Canyon|1996 Ducati 750 Monster
Snowshoe is offline
post #12 of 25 (permalink) Old Apr 12th, 2017, 10:30 am
How are you planning to adjust the caliper mounts to accommodate the new, smaller diameter rotors?
Mike Santa Barbara, CA / Whidbey Island, WA
'15 MTS-S Touring, 99 Ducati 996, '07 BMW R1200S
2wheelmike is offline
post #13 of 25 (permalink) Old Apr 12th, 2017, 10:42 am Thread Starter
Snowshoe's Avatar
By removing the spacer that sits between the caliper and the mount.
If the thread length on the bolt hole is not long enough the spacer can be placed between the bolt head and the caliper. I will take a look at the parts manual to see if there is a difference between the bolt on the "S" vs. standard MS.
Sent from Android using TapTalk
Maxmach likes this.
Snowshoe is offline
post #14 of 25 (permalink) Old Apr 12th, 2017, 11:52 am
DaveK's Avatar
I've finally gotten the bike out after a long winter and have a couple hundred miles on the EBC pads... I'd say they have a more aggressive initial bite compared to the stock pads, but overall braking is very similar (which is to say... excellent).
I've personally not had any issues with the stock rotors (so changing to a different size or brand isn't in the cards for me), and the EBC pads seem to have cured the 'groaning' that the stock pads had when pushing the bike around the garage.
23k (almost all highway) miles out of the stock pads, they weren't completely shot but were close so they went into the bin.
15 Multistrada S Touring/Urban/Enduro, 04 Tiger 955i, 86 MaximX 750 (son), 82 Maxim 550 (wife)
DaveK is offline
post #15 of 25 (permalink) Old Apr 12th, 2017, 1:26 pm Thread Starter
Snowshoe's Avatar
By removing the spacer that sits between the caliper and the mount. I will take a look at the parts manual to see if there is a difference between the bolt on the "S" vs. standard MS
Yes, there is a difference. The one for the S model is 60mm (77913311D) vs. the standard which has a 55mm. (77915111B). So you have 2 options. Move the spacers from the front of the caliper to the back, or if you're a purist - order the other screw.
Now, the hole in the fork mount goes through - meaning it does not have a bottom so it may just be able to accept an additional 5mm. I will see when I install. Unless anyone has a different opinion I can't see how moving the spacer from one side to the other is an issue?
Snowshoe is offline
post #16 of 25 (permalink) Old Apr 12th, 2017, 9:33 pm
wow! thank you for the thoughtful reply. my need is a little different - I want a spare set of wheels set-up for trails with off-road tires. I have the wheels and tires from a friend but his rotors are 320mm. I was concerned running 320mm sometimes and 330mm at other would wear the pads unevenly and poorly. Maybe I should buy a second set of 320mm rotors and just run that size all the time?
minimalist is offline
post #17 of 25 (permalink) Old Apr 13th, 2017, 1:25 pm
multimike's Avatar
I did the same thing , I got a set of OZ rims and wanted to put trail tires on the stock rims. I got the Iron rotors in 320MM and removed the 5MM spacers and used the stock caliper bolts without an issue and without putting the spacers on the other side of the bolts. This helped alot with getting the calipers on and off the new rims as the they a different shape and removing the calipers with 330 MM roters was REALLY tight. Works great , dont forget to order the slotted, ABS sensor that goes under the rotor before you do all this work. I Really love the new rims & rotor setup. Now I can switch out the weels and rear sprocket on a quick change hub to go into trail mode (14- 41 gearing).
Name:	IMG_4023 (002).JPG
ID:	808617   Click image for larger version
multimike is offline
post #18 of 25 (permalink) Old Apr 13th, 2017, 4:10 pm Thread Starter
Snowshoe's Avatar
@multimike , I don't understand this statement? Under the rotor, it is on the outside beside the sensor now?
Snowshoe is offline
post #19 of 25 (permalink) Old Apr 13th, 2017, 6:00 pm
multimike's Avatar
Look at the front rotors, on one side there is a slotted disk, harmonic something or other its officially called. The actual sencer is on the fork tube but needs this disk to read tire rotation for the ABS, it's mounted between the rotor and hub. If you want different tires on different rims it's best to fit them with rotors and to do that you will need this disk. The rotor bolts get really tight with the heat and are hard to remove, you need an impact driver and don’t want to do that every time.
post #20 of 25 (permalink) Old Apr 13th, 2017, 7:56 pm Thread Starter
Snowshoe's Avatar
We must be talking in reverse of inside and outside. My phonic wheel is mounted on the outside of the rotor.
photos from my factory installed, and shop manual
ID:	808737   Click image for larger version
Name:	shop manual abs.JPG
ID:	808745   Click image for larger version
Snowshoe is offline
Human Verification
FERODO ST Front Sintered Brake Pads: Brembo 4 Pad moto Motowheels 0 Oct 5th, 2016 11:35 am
EBC Brake Pads for 2015 DVT elitexen Multistrada 8 Sep 28th, 2016 4:13 pm
FERODO ST Front Sintered Brake Pads: Brembo Dual Pin moto Motowheels 0 May 7th, 2016 9:53 am
FERODO PLATINUM Organic Front Brake Pads: Brembo Single Pin moto Motowheels 0 Apr 12th, 2016 8:18 pm
FERODO XRAC Sintered Front Brake Pads [Trackday/Race 8.5mm thick]: Brembo 4 Pad moto Motowheels 0 Apr 11th, 2016 7:17 pm
