2013 1200S Header Cracked - Ducati.ms - The Ultimate Ducati Forum
post #1 of 11 (permalink) Old Mar 20th, 2017, 9:44 pm Thread Starter
I just noticed my header has a crack on the left side of the engine. What are my options for getting a new stock pipe or aftermarket? Been doing a bit of searching for an aftermarket system but no luck on a full system.
How accessible are the nuts? Do I have to remove the gas tank? :/
markomarkovich is online now
post #2 of 11 (permalink) Old Mar 20th, 2017, 11:08 pm
Buhgaboo's Avatar
oem ducati...startwin netharlands...I get all my parts from them
Buhgaboo is offline
post #3 of 11 (permalink) Old Mar 21st, 2017, 1:23 am
aschemkes's Avatar
Get it welded. Much cheaper
Verzonden vanaf mijn iPad met Tapatalk
Multistrada 1200S DVT 2016 Touring pack, the Netherlands
aschemkes is online now
post #4 of 11 (permalink) Old Mar 21st, 2017, 8:42 am Thread Starter
Just ordered one on eBay. How accessible are the nuts? Do I have to remove the gas tank? :/
post #5 of 11 (permalink) Old Mar 21st, 2017, 8:48 am
MTScott2's Avatar
Images: 5
look at the manual, loads of info there, decide if you are up for it Have fun,
True story I saved a few bucks doing exhaust on an old truck. 4 stitches at the emergency room, Some things are better left to the professionals...
Bad decisions make for good stories
Take my Advice, I don't use it.
2011 Red Multistrada S Touring
MTScott2 is offline
post #6 of 11 (permalink) Old Mar 22nd, 2017, 8:39 pm Thread Starter
I bought the manual. Unfortunately only shows how to remove it on an engine. Without the engine being on the bike. Anyone have any info on how hard it is to remove the vertical or rear exhaust manifold off the engine while it's in the bike?
post #7 of 11 (permalink) Old Mar 22nd, 2017, 9:15 pm
Buhgaboo's Avatar
block up under the engine (assuming its on a Stand) Remove the rear shock easy access . . . Remove Lambda sensor, Loosen guard
Buhgaboo is offline
post #8 of 11 (permalink) Old Mar 22nd, 2017, 9:25 pm
MTScott2's Avatar
Images: 5
step one remove engine.
MTScott2 is offline
post #9 of 11 (permalink) Old Mar 22nd, 2017, 9:27 pm
MTScott2's Avatar
Images: 5
try you tube next step.
MTScott2 is offline
post #10 of 11 (permalink) Old Mar 23rd, 2017, 8:35 am
You need a 10mm swivel socket and extensions, it can be done but the nuts are soft, almost copper? They round easily so beware. My rear 02 bung blew out a couple years back and I had to swap mine out as well. Used, I bought a pair. I never touched the engine mount bolts, just swivel socket, extensions, and I believe a ratchet wrench from the right side.
Its doable, just be patient.
2011 1198
2012 MTS 1200 ABS
Past Bikes, 1985 RZ-350, 1988 FZR400, 1994 CBR-F2(RACE), 1998 TL-S, 2001 R6, 2002 CBR 954, 1999 R6(RACE), 2004 CBR 1000RR, 2005 R1, 2008 CBR 1000RR, 2005 ST3
fastrob691 is offline
Human Verification
Monster - my next bike. Struggling deciding between 1100 Evo or 1200S mister704 Monster 10 Nov 21st, 2016 9:55 pm
How much off roading can 1200S handle? Does bad road / no road count as off roading o Amit Rana Multistrada 34 Oct 10th, 2016 11:46 am
Multi 1200S 2013 - how to remove spark plug Stavrich Multistrada 5 Jun 2nd, 2016 10:37 am
Skyhook setup - 1200s - 2013 Stavrich Multistrada 14 Apr 22nd, 2016 10:18 am
2013 M1100 EVO& 2013 MTS1200 gauge swap fastbymarcus Tech Forum 0 Jan 10th, 2016 6:24 pm
