Front sprocket change: impressive - Ducati.ms - The Ultimate Ducati Forum
post #1 of 29 (permalink) Old Mar 19th, 2017, 8:16 pm Thread Starter
I had the MS in for fluid changes and had the front sprocket sized down to a 14. The dealer was unwilling to change the rear to a 42 without replacing the chain, and I'm a ways from needing a chain, so went with the front only. Wasn't expecting a whole lot of difference, but to my surprise it actually is quite a difference.
With the stock ratios, I rarely got out of third gear (we're limited to 55 mph around here, and don't see that too often with traffic). Now 55 mph in fourth gear is right at 4000 rpm, which seems to be a sweet spot for my motor, and fifth gear is a possibility. Ratios are a bit closer together, which I like, and while out riding in the hills with the Mrs on board everything was nice and smooth, with easy power even in urban mode.
For a very inexpensive mod, there's a lot of value here. I'm looking forward to wearing my chain out and putting that 42 in the back.
2014 Multistrada GT
Past: BMW 1150 GS, Moto Guzzi Norge 8v GT, some sort of Honda
nikwax is offline
post #2 of 29 (permalink) Old Mar 19th, 2017, 8:35 pm
Any known issues with the chain wearing into the swingarm or other areas? I only ask as I'm coming from the Monster world where that can be an issue, but I'm in the market for a MS and that might be something I'd end up doing.
PooveyB is offline
post #3 of 29 (permalink) Old Mar 19th, 2017, 11:47 pm
rambler358's Avatar
What's the difference in speedometer readings now?
rambler358 is offline
post #4 of 29 (permalink) Old Mar 19th, 2017, 11:55 pm Thread Starter
I've not read of any.
2014 Multistrada GT
nikwax is offline
post #5 of 29 (permalink) Old Mar 20th, 2017, 12:03 am Thread Starter
same, the speedo reads off of the wheel rotation and not the engine rotation AFAIK. At any rate, I don't see a difference vs GPS speed.
BTW, the gearing difference is, I believe, about 7%, which actually is kind of significant (I think 5% is the threshold for significance...or is that with bicycles?)
2014 Multistrada GT
nikwax is offline
post #6 of 29 (permalink) Old Mar 20th, 2017, 4:34 pm
macraige's Avatar
This website will give you more information about sprocket changes that you can ever use or imagine:
Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
AND, its free.
2012 Multistrada S Touring, Full Termi System,
2010 848 Hayden SE Full Termi system,
2004 BMW R1100S BCR, Ohlins & Staintune,
2010 Vespa GTS 250ie.
macraige is offline
post #7 of 29 (permalink) Old Mar 21st, 2017, 1:24 am
6point5guy's Avatar
Tea-review down is good on multi
1 down on the counter shaft sprocket is a great mod on the Multistrada. These bikes are geared to high, as most bikes are these days, to begin with. It's cheap and gives BIG dividends. I did mine right away and never looked back. No I'll side effects.DO IT...
wmfleet2 likes this.
2013 Multistrada Pikes Peak
Termignoni system
Brembo Monoblocks
Ferodo XRAC pads in front
Oberon Clutch Slave Cylinder
-1 on countershaft
Heated grips
Panniers
Crash protection
CRG levers
Blinder HP-905 Laser defeat
Valentine one
Autocom communication
6point5guy is offline
post #8 of 29 (permalink) Old Mar 21st, 2017, 11:02 am
PhilBoncer's Avatar
Originally Posted by nikwax View Post
... For a very inexpensive mod, there's a lot of value here. I'm looking forward to wearing my chain out and putting that 42 in the back.
I'd advise against a 14/42 combination. Having the rear sprocket be a multiple of the front sprocket isn't good; every 3 rotations the chain will line up on exactly the same teeth on both, exacerbating wear variations. You're better off technically, for longevity of both the chain and the sprockets, with tooth number combinations that don't match up so neatly. Either 14/41 or 14/43 would last better.
PhilB
shorton likes this.
1993 Ducati Monster M900, bought new, 260K miles (so far)
PhilBoncer is offline
post #9 of 29 (permalink) Old Mar 21st, 2017, 5:30 pm
Official Sponsor
PhilB
I'm glad you pointed that out.
The makers specifically engineer things to avoid these types of issues and riders sometimes dig themselves a hole by ignoring these types of things.
But strangely, the Cagiva Gran Canyon came with 15/45.
HTH.
M./
Innovative Electrical Upgrades Since 2002 |*EVERY* motorcycle will start in 1 second or less if the starting circuit is properly engineered. Install our HICAP II starting circuit upgrade to the get quick easy starting you expected from your high-performance engine. Excess cranking accelerates wear on the; battery, starter motor, sprag clutch and intermediate gear. - - Pay a little now or pay a lot more later. Click to learn more Motolectric.com |
motolectric is online now
post #10 of 29 (permalink) Old Mar 21st, 2017, 6:33 pm
Ricko's Avatar
PhilB
That is semi-true.
This is only a problem if the number of links on the chain is also a multiple of a sprockets. In your 42 rear example, a chain with 84 or 126 links would be at the same place on the rear sprocket 2 or 3 times per revolution of the chain. Otherwise, no problem.
On the front, 112 links would give the same tooth same link 8 times at every revolution of the chain.
M./
For the same reason, only a problem with a 90 or 120 link chain.
pmrobert and jahjah like this.
Macs are like Harleys... For wannabe different people, who get all the same sh!t
Ricko is offline
Human Verification
Ducabike Billet Front Sprocket Cover: Scrambler, Monster 821 moto Vendor Specials and Group buys 0 Dec 22nd, 2016 7:46 pm
Ducabike Billet Front Sprocket Cover: Scrambler, Monster 821 moto Vendor Specials and Group buys 0 Sep 24th, 2016 11:23 pm
Ducati 748-998/ S2R 800/ MH900e: AFAM Quick Change Sprocket Kits moto Vendor Specials and Group buys 0 Mar 30th, 2016 8:56 pm
Question About 14T Front Sprocket on Monster 1100 Springbok_Rider Monster 19 Mar 27th, 2016 10:44 pm
Ducati 748-998/ S2R 800/ MH900e: AFAM Quick Change Sprocket Kits moto Motowheels 0 Mar 25th, 2016 11:21 am
