Milky substance in oil level window. - Ducati.ms - The Ultimate Ducati Forum
post #1 of 26 (permalink) Old Dec 12th, 2013, 6:29 pm Thread Starter
I have thin milky substance in the oil level window. Is this something to be worried about. Bike is a 2013 with 4000 miles.
Thanks in advace
coolj4311 is offline
post #2 of 26 (permalink) Old Dec 12th, 2013, 6:36 pm
A 748 Fanatic
Ducati 748 Delaware's Avatar
My thoughts
Moisture in oil - may be condensation. You might need to ride longer if your only doing short rides. Full operating temperature should dissipate the moisture unless there's a cooling system issue.
If you suspect such, watch your coolant level and oil quantity to see if coolant is moving to the oil.
Do a fresh oil change and start from scratch and / or do a pressure check of the cooling system to detect an internal leak.
Ducati 748 Delaware is offline
post #3 of 26 (permalink) Old Dec 12th, 2013, 6:37 pm
Sounds like water to me.
Handsome_Rob is offline
post #4 of 26 (permalink) Old Dec 12th, 2013, 6:39 pm
...what he said
2014 Ducati Monster M1200S (Red)
tomfromON is offline
post #5 of 26 (permalink) Old Dec 12th, 2013, 7:10 pm
The days are getting longer!
va duc's Avatar
Images: 12
Oh go ride the damn thing for more than twenty miles, its all good.
AMA Member
1998 Silver ST2$
Motto Guzzi G2 Moped
va duc is offline
post #6 of 26 (permalink) Old Dec 12th, 2013, 7:26 pm
Milky oil
So it may be just condensation. But if it were mine I would have the dealer eyeball that and document that event. That's not a cheap bike. I'm going with covering your ass just in case.
Rosco61 is offline
post #7 of 26 (permalink) Old Dec 12th, 2013, 8:13 pm
t-bills's Avatar
Mine does this in the winter. It is just moisture building up. Long rides don't necessarily rid it for me. In cooler temperature (<60F), my bike will operate at 150F which isn't enough to boil off the moisture. Ride it through town at lower speeds to get the temps up.
Note that this is completely normal and not harmful.
Thomas Williams
2011 Multistrada 1200S Touring (Red)
2012 Hypermotard 1100 Evo SP
How to change a tire by hand, How to guide Desmo service of Hypermotard
t-bills is offline
post #8 of 26 (permalink) Old Dec 12th, 2013, 11:44 pm
Images: 109
+1. I've actually let mine idle after a winter ride to get hot enough to burn it off.
Current bikes:
2006 BMW HP2 Enduro
1994 ATK 406
marret is offline
post #9 of 26 (permalink) Old Dec 13th, 2013, 5:31 am
kma_jg's Avatar
Long rides is not always the fix. I did 1500km in three days and on the third day I noticed the milkyness. It was very cold that day. Raining, light snow in one stretch and the dash temp was 2 degC.
Recommend action is to let the temp go as high as possible. Turn off the bike and open the oil filler plug to let the moisture out.
Sent from Motorcycle.com Free App
Johan
2012 Titanium Multistrada 1200S Touring, 101 000km and counting
kma_jg is offline
post #10 of 26 (permalink) Old Dec 13th, 2013, 6:36 am
bmwstrider's Avatar
Check your cylinder head bolt nuts. My friend on a trip, had the lower left nut on horizontal cylinder work loose over time. Oil window looked like milky grease and would not go away. He only had like 1500 miles or so.
His was easy to see, while motor idling the nut was vibrating. The other 3 are harder to get to and require a special C shaped tool to access and torque properly.
14 KTM 1190 Adv
bmwstrider is offline
Human Verification
06 Sport 1K - White Splatter on Oil Level Window? Jules Winfield Sport Classic 16 Mar 22nd, 2013 6:51 pm
question about oil level window blevy1 Sport Touring 1 Mar 5th, 2013 9:50 am
Cloudy oil level window LeFauxTard HyperMotard 8 Dec 5th, 2011 10:37 am
White fluid in oil level window. dimitrinassis001 HyperMotard 8 Nov 23rd, 2011 5:18 am
Oil level view window russclimber Supersport 5 Jan 27th, 2007 10:51 pm
