Quick shift Kit for the TuneBoy system - Page 18 - Ducati.ms - The Ultimate Ducati Forum
View Poll Results: Are you interested in an MTS 1200 QS kit from Tuneboy
Yes please! 47 83.93%
No interest. 9 16.07%
Voters: 56. You may not vote on this poll
post #171 of 546 (permalink) Old Jan 26th, 2014, 9:59 am
belgiumexpat's Avatar
I think it is a software bug as well. My throttle position is 2.5% as well so that may be the "startup" value.
The previous version I was using doesn't do that so it has to be in the .dat file.
I'm not sure about the 40km thing though. I thought that it was at any speed. I've noticed that if i let off the throttle for a long period (10-20 meters or so) it will eventually feel like the butterflies have closed.
A little bug in the pursuit of perfection!
Originally Posted by marret View Post
Interesting. Thanks belgiumexpat. So we can both change modes with the same method. Sounds like a map/software issue which is what I was thinking.
I sent the email to Tuneboy. I may try reflashing with the previous MTS1200_CruiseAndTuning_Tune to see if the problem goes away. I wanted to see what Tuneboy says first.
When I turn the ignition on but not start the engine, my throttle position is 2.5%. I don't know if this should be 0.
I thought the 40kph interesting because I remembered something about that being the minimum speed to engage the CC. Another reason to think it is software related. I was hoping that Tuneboy could tell me to change a specific value in the trim program.
2013 Ducati Multistrada Granturismo
2014 Ducati 1199r Panigale (Track Mule)
belgiumexpat is offline
post #172 of 546 (permalink) Old Jan 26th, 2014, 10:09 am
Images: 109
Right, a little bug in the pursuit of... I do have to admit I was a little nervous when the bike stalled and I got the error message...how and when am I going to be able to retrieve the bike...
I tried your recommended blip value of 5, but it caused my blip to be too far in advance of the downshift. If I used very light pressure on a downshift I would get two blips. I moved it to 7 and went out again. That seems better for my bike. Part of it may be operator induced as well.
Current bikes:
2006 BMW HP2 Enduro
1994 ATK 406
marret is offline
post #173 of 546 (permalink) Old Jan 26th, 2014, 11:35 am
I'm thinking at this point that the run-on throttle is causing some of this. I moved mine back to 6. I think the throttle staying open isn't helping. I will probably disable the downshift until a fix is available...
I put one of those fancy "cush drives" in. I am going to put the stock bushings in tomorrow and see if that makes any difference in how it feels. The bike pulls really hard with the 15/42 gears so its kinda hard to try keep everything straight when you do multiple changes at once. I'll update tomorrow with the stock cush drive in.
post #174 of 546 (permalink) Old Jan 26th, 2014, 11:46 am
Images: 109
Makes sense, be good to rule out things. Not sure if I'll have time this week and next weekend I'll be on a ski trip, but I'll follow your posts and post up what I find when able.
Thanks.
Current bikes:
2006 BMW HP2 Enduro
1994 ATK 406
marret is offline
post #175 of 546 (permalink) Old Jan 26th, 2014, 4:05 pm Thread Starter
All weather biker
nemesis.ie's Avatar
I'm seeing the same thing on my 2013 with stock gearing.
It must be something in the TB base map if it's affecting 2013 and 2010 bikes and going back to the v2 code it goes away.
I'm sure Wayne will find it and send us an updated version soon.
2013 Multistrada 1200S Touring, matte chrome
TB CC and QS with SC Project 3/4 system & air filter
TB is great, the SC is not good quality/design-wise.
nemesis.ie is offline
post #176 of 546 (permalink) Old Jan 28th, 2014, 5:10 am
TiDuc's Avatar
Mine finally arrived and I am well chuffed to get it installed today, but I got a question or 2, can you guys clarify?
The install went great. There is a yellow sheet that comes with the quickshifter with some info and there is also a install document included with the software download. RTFM and you will be fine. ......You have to email Emma for the software!
Expat- you said the QS came with an "install document" and also mentioned it's recommendations for settings...All I got was the Yellow sheet
Any chance somebody can post or email me a copy of the install document. You also said you have to email Emma for the software....Anyone have any idea if this is the software Emma sent on post #163, or this something different again? Emma even says in her post to follow the instructions carefully...What instructions? Is it embedded in the ZIP file she posted??? I'm at work now and canít download the .zip file to check, and I really would like to know I have everything to proceed tonight, and I really canít afford to screw this up since I killed my car last weekend and need my bike.
BTW it was 1 degree and frosty on the way to work this morning, In Tuscany ...BBBrrrrr....The bike still rocked, loving the new flywheel and revised cam timing, sound nasty!
2011 Multistrada TUNEBOY equipped Dry STM slipper clutch... and some tricky bits inside the motor
W/Real Ohlins manual TTX shock and 30mm TTX cartridges & BSTs
TiDuc is offline
post #177 of 546 (permalink) Old Jan 28th, 2014, 5:21 am
Images: 109
Correct, the install document was with the zip files Emma posted a page back. Have to update the WB-01 first. Again, the program is in the zip. New FlashMitsubishi and TuneboyTrim programs.
One thing to note the new install directions focus on just the QS itself, not flashing the ECU which is the same as the previous instructions.
I should be able to email if you send me an email address.
Current bikes:
2006 BMW HP2 Enduro
1994 ATK 406
marret is offline
post #178 of 546 (permalink) Old Jan 28th, 2014, 6:40 am Thread Starter
All weather biker
nemesis.ie's Avatar
Another thing to note is you may have to do both the "pre-flash" and then the "normal flash". I had to redo the pre-flash but this may just have been as I was using a freshly installed laptop that had not connected to the bike before.
The bike will not run if you only have the pre-flash installed.
post #179 of 546 (permalink) Old Jan 28th, 2014, 6:59 am
I thought sometimes "that shift could have been a little smoother". I recently (a day or so before the quick shifter arrived) installed a 15/42 quick change with the new fancy dancy cush drive. The stock drive is made of rubber where the fancy one is made of a much harder material. After a quick jaunt around the neighborhood it makes the shifts notably softer with the stock cush drive. I have probably 500 km on the quick shifter and drive but only put 20 km or so in my simple test. I have a busy day of work so not able to really put a lot of seat time in testing it but the results so far are pretty dramatic.
post #180 of 546 (permalink) Old Jan 28th, 2014, 2:51 pm
TiDuc's Avatar
The link Emma posted up is V3. Does anyone have V4? or is there someplace to download it. I would think it best to start with the latest version? I know Wit posted he was using V4 and loved it. Unfortunately family life is preventing me from freezing my ass off in the garage installing this tonight. But at least I downloaded the new updates into the laptop. I think I may need to wait till this weekend to complete the install. Thank you guys for the assistance
TiDuc is offline
Human Verification
Special: TuneBoy Advance Ducati Starter Kit TuneBoy Vendor Specials and Group buys 22 Aug 31st, 2015 10:41 pm
SPECIAL: TuneBoy Advance Kit Panigale/MTS1200/Diavel TuneBoy Vendor Specials and Group buys 5 Jul 8th, 2013 9:07 am
quick shift LouEyez Multistrada 0 May 14th, 2012 2:37 pm
Quick shift Punch Supersport 9 May 9th, 2011 7:24 am
