Problem with my dashboard - help needed - Ducati.ms - The Ultimate Ducati Forum
post #1 of 15 (permalink) Old Mar 21st, 2012, 4:46 pm Thread Starter
Hello all,
I´m posting this to see if anyone here on the forum experienced this issue and/or know anyone who has...
Two days ago my dashboard is showing the right turning signal dimmed even when not activated. It occurs when any other light (ABS, N, etc) on the dashboard is on. As soon as all the lights are off the turning signal works fine.
Don´t know what it is and i´m asking the forum members if they know the reason for this.
Thanks all in advance!
My video:
MTS1200 dashboard problem.mp4 - YouTube
P.S - sorry for the poor quality
JP Portugal is offline
post #2 of 15 (permalink) Old Mar 21st, 2012, 6:23 pm
Bad earth
Check if any of the 4 indicators are dimly lit too
Ezituper is offline
post #3 of 15 (permalink) Old Mar 22nd, 2012, 12:53 am
riva996's Avatar
I have not had that experience. I recall someone else saying that they thought it was a bleed over from the abs light?
Let us kno if you find it is an electrical issue.
'12 Pikes Peak #195
'16 Multistrada Enduro
riva996 is offline
post #4 of 15 (permalink) Old Mar 22nd, 2012, 2:35 am
You need to replace the dashboard.
https://picasaweb.google.com/1113426...25432201343042
Ducati Paul Smart LE1000 & Ducati Multistrada 1200s
MrSweden is offline
post #5 of 15 (permalink) Old Mar 28th, 2012, 5:46 am
My dasboard is having a similar problem, but with the hazard lights in the top right hand corner. It is not consistent, but the leds light up very faint in different combinations. I have a 2010 S and the dashboard will be replaced under warranty.
Eric
Eric
Kudelstaart, the Netherlands
Current: MTS 1200 S Touring White
Ducatis Owned & Used:
Ducati ST4S ABS, 140.000 km destroyed by a car running a red light
Ducati ST2, 80.000 km
Ducati Paso 906, 65.000 km
Ducati Paso 750, 12.000 km
eonderde is offline
post #6 of 15 (permalink) Old Mar 28th, 2012, 8:19 am
TiDuc's Avatar
Others with a similar issue...Good luck!
Engine warning light weirdness
2011 Multistrada TUNEBOY equipped Dry STM slipper clutch... and some tricky bits inside the motor
W/Real Ohlins manual TTX shock and 30mm TTX cartridges & BSTs
TiDuc is offline
post #7 of 15 (permalink) Old Mar 31st, 2012, 9:33 am
I had the same problem, some dashboard lights stayed on dimmed. I discussed this with my dealer and they put on a new dashboard under warranty.
Solved perfectly, the only thing is that my 'milage' is back to zero, but for this my dealer made a remark in my book of maintenance.
biancanera is offline
post #8 of 15 (permalink) Old Apr 17th, 2012, 11:05 am
kfj
Im having the same problem. You would think they would be able to reset the milage for the bikes
2010 MTS1200 ABS White
2009 HD XL1200N SOLD
kfj is offline
post #9 of 15 (permalink) Old Apr 20th, 2012, 3:51 am
kfj Im having the same problem. You would think they would be able to reset the milage for the bikes
I asked that but this was not possible, because of avoiding changed milages when bikes are on sale.
post #10 of 15 (permalink) Old Apr 20th, 2012, 10:06 am
...which, of course, makes NO sense, as they have already changed your mileage by changing it to ZERO. And you are asking them to ADD mileage, not reduce it, which would should not present any type of moral dilemma at all.
ZenRider is offline
Human Verification
De-blinging the dashboard poolagent Sport Classic 26 Jul 2nd, 2016 11:37 am
What is the red flash on dashboard for? nethern HyperMotard 22 Nov 9th, 2011 9:29 pm
Dashboard Ciccio Bkk Sport Classic 18 Jan 30th, 2010 12:35 pm
Finally my new dashboard...... Luca_M Superbikes 34 Oct 30th, 2009 11:21 am
DashBoard update for 748 748Rider Superbikes 1 Sep 7th, 2007 10:39 am
