ABS not working - Ducati.ms - The Ultimate Ducati Forum
Old Feb 2nd, 2012, 7:34 pm   #1 (permalink)
ABS not working
Just rode my new 12' this past Wednesday after picking it up two weeks. Living in Iowa during the winter makes riding a hit and miss. We'll the weather was fine yesterday so this was a hit moment. After getting rolling, the DTC light went off and the ABS light never went off. The amber light stays on all the time. I stopped and turned the DTC on again and the same thing happened. It like it's sensing a fault with the ABS and kicking the traction control off. Has anyone had any problems with the ABS light staying on and not working? I'm sure the traction control is kicking out because of this also.
mkr1966 is offline   Reply With Quote
Old Feb 2nd, 2012, 9:35 pm   #2 (permalink)
minusone's Avatar
I would check the wiring and plugs for the wheel sensors, particularly the rear one. Could be a bad connection or damaged sensor.
[ Current Rides ]
Gas Gas Raga Replica
Husky TE450
KTM 690 Enduro Rally Raid
Hypermotard 1100S
Multistrada 1200S
Old Feb 3rd, 2012, 1:08 pm   #3 (permalink)
Will have to look for the wire. You would think it would throw a fault code?
Old Feb 4th, 2012, 3:46 am   #4 (permalink)
minusone's Avatar
Yes, in that case it may be something is preventing the sensor registering a signal. Is the mounting bent or damaged that may have interfered with it.
Anything obscuring the sensor?
Is the speedo working ok?
[ Current Rides ]
Husky TE450
Hypermotard 1100S
Multistrada 1200S
748 Rad Fan Not Working CanadianWraith Superbikes 2 Jun 15th, 2011 6:58 pm
lights not working dep378 Superbikes 6 Apr 6th, 2008 2:09 pm
I am just about over with working on my 999 FloridaDuc Superbikes 34 Feb 9th, 2008 4:41 pm
748 speedo was working then stopped working. zerofighter Superbikes 2 Apr 14th, 2007 1:27 am
