Touratech handguards finally installed - Ducati.ms - The Ultimate Ducati Forum
Old Jan 29th, 2012, 11:30 am   #1 (permalink)
Sock Monkey's Avatar
It took a while to get around to installing my Touratech hand guards, but they're finally on and I like how it all turned out. I didn't use the signals included in the kit, and instead purchased the DP mirrors with integrated turn signals. This had the side benefit of providing much better rear vision because the DP mirrors are rock steady, where the stockers were a bit blurry. The DP mirrors are also lower profile, and less likely to get nicked in a fall (touch wood.....).
This combo is probably the least economical solution out there (sadly), but it accomplished my goals:
1) Protect both the levers and the perches. The DP hand guards still attach to the perches. BAD idea! Stresses on the hand guards in a fall will transfer some of that to the perch, which could have disastrous results (lose your perch and your're worse off than if you snapped a lever). The Touratech hand guards come with new clamps that attach directly to the bars.
2) Provide better coverage than the BarkBusters. While the BB's look to be the best "bang for the buck" solution out there, it looks to me like a tip over in rocks could still result in broken bits. I got the additional "spoilers" with the Touratech hand guards (that match the Ducati red exactly), and together they provide a LOT of coverage.
Now a couple of "gotchas". First, replacing the mirrors is another trip down "remove the tank" lane. 4hrs there and back again. I've done this enough times now that it's easy, just time consuming. Second, these hand guards are NOT compatible with my Throttlemeister throttle lock....but $2 at the local hardware store fixed that, and now my throttle lock works perfectly again. I won't bore those who don't care with the details, but if anyone wants to know, PM me and I'll go through it. Here's a hint: all you need is a steel spacer and a washer modified for the correct ID.
I've attached a couple pics so you can see the final result.
Ride safe everyone.
-SM
Edit: I forgot to put this in my original post. I've heard that the folks at the Touratech factory might be willing to sell just the hand guards and associated bits, leaving out the turn signals, wiring, and brackets, for a reduced price. If someone wants to check with them and report back, that would be great. Again, this would be from the factory only (in Germany), and NOT something you could get from your regional distributor.
Touratech handguards finally installed-small_dsc5154.jpg   Touratech handguards finally installed-small_dsc5152.jpg
Current:
2010 Ducati Multistrada 1200 S Sport
2008 Yamaha WR250R
Gone:
Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old Jan 29th, 2012, 3:26 pm   #2 (permalink)
there's a shortage of dwarfs
w0mb2t's Avatar
looking good SM
w0mb2t is offline   Reply With Quote
Old Jan 29th, 2012, 4:10 pm   #3 (permalink)
kma_jg's Avatar
That looks very good. I just don't like those mirrors with the indicators on them. It looks bent.
Johan
2012 Titanium Multistrada
My Vimeo Channel
kma_jg is offline   Reply With Quote
Old Jan 29th, 2012, 4:52 pm   #4 (permalink)
oalvarez's Avatar
Sock, I really like how it turned out, job well done. I personally like the DP mirrors very much.
Fit, form, and function...nice!
2012 Ducati MTS1200St Ti
2003 Aprilia Tuono Racing
oalvarez is online now   Reply With Quote
Old Jan 29th, 2012, 5:29 pm   #5 (permalink)
Timthai's Avatar
I like it a lot!
I've been mulling over the best way to go, and this looks like it to me.
Maybe not the cheapest, but that never stopped me before!
Thanks for the update.
cheers.
"Dream like you'll live forever, Live like you'll die today!" James Dean
- 2011 Ducati Multistrada 1200S/S
- 2011 Kawasaki Vulcan 900
- 2010 Kawasaki Ninja 650 (about to go to make room for a new 795 Monster!)
- 2012 Kawasaki Ninja 250
- Not as much time as I'd like to ride them!
Timthai is offline   Reply With Quote
Old Jan 29th, 2012, 6:12 pm   #6 (permalink)
Turbo's Avatar
The more I see these guards on, the more I want them, but I don't need half the kit they sell. I have the DP mirrors and Rizoma reservoirs with Rizoma mounts, so all I want and need are the hand guards. I'll give them a call on Monday and see what we can negotiate!
Mark
2010 WHITE Multistrada 1200s Touring
Turbo is online now   Reply With Quote
Old Jan 30th, 2012, 5:11 am   #7 (permalink)
Originally Posted by Timthai View Post
I like it a lot!
cheers.
+1 Mr Sock. Very nice. The red spoilers are a great color match !
cheers,
wit c.
unreliable heap of shit (red)
DP Top box + HFF + Alarm
11-Aug-2010
(http://www.madcogz.com/ms-data.htm)
MODIFICATIONS
DP CF tail tidy - (www.proitalia.com)
RadGuards - (radiator + oil cooler) (www.radguard.com.au)
SW Motech header guard - (www.motorradgarage.com.au)
SW Motech crash bars - (www.motorradgarage.com.au)
SW Motech Hawk radiator light mounts - (removed due to recall)
SW Motech Hawk fairing mounts - (installed after all ... looks OK)
sheepskin seatcover - (www.goodwool.com
Givi touring screen - (ebay)
mivv decat and suono slipon (http://www.pjsparts.com/)
Denali D2's - ( www.twistedthrottle.com )
SupaBrake brake flasher. ( www.vizi-tec.com )
FatDucs O2 manipulators. (removed www.performanceboulevard.com)
Touratech Handguards
powdercoated bellypans and exhaust guard
CP-Wings
Headlight protectors
WARRANTY ISSUES(wrnty) DES rear shock Replaced. (mar 2011)
(wrnty) clutch mc replaced (mar 2011)
(wrnty) 2011 recall updates, fuelling ABS and Dash (may 2011)
(wrnty) DES Rear Shock ECU replaced (jul 2011)
(wrnty) 2011 recall updates, Handsfree, switches (jul 2011)
(wrnty) pourus Cylinder Head replaced (5-12-2011 to 19-1-12)
(wrnty) sudden coolant leak at 26700+km (May 2012)
REPAIRS
(idiot) jammed gearshift. fixed now. thankyou QBE.
WEAR and TEAR(wear) Chain/Sprockets toast & rear disk at min thickness at 26,700km
REASON in SHOP today ?Unbelivably FRASERS have been unable to source a new chain for 8 days now (and counting).
651 days old and 26,700+ km travelled as at 22nd May 2012
wcieslik is offline   Reply With Quote
Old Jan 30th, 2012, 6:42 am   #8 (permalink)
MTScott2's Avatar
Images: 5
Looks GOOD!
some more pics from different angles so we can get some more conflicting reviews /views???
Any and all info can never be Boring!!!
2011 Red Multistrada Touring
Old Jan 30th, 2012, 11:18 am   #9 (permalink)
Thanks everyone for the kind replies. I'm pretty happy with how it turned out, even though my bank account is still reeling from the beating it took.
I agree that while the DP mirrors are smaller, I like them better because they offer a crystal clear view vs. the fuzzy view that my stockers gave me. Smaller but clear beats larger and fuzzy in my book.
MTScott2, let me know what other angles your looking for, or if there's something specific you want to see (like the hydro fluid res mounting brackets, mounting points on the bars, etc).
-SM
Current:
2008 Yamaha WR250R
Gone:
Old Jan 30th, 2012, 11:39 am   #10 (permalink)
joeducati's Avatar
Looks fantastic! Love the red handguards! Your stock mirrors were fuzzy? My stockers are pretty clear, best mirrors I've had on a cycle, mainly due to being set out so far, compared to sport bikes that is.
(Sold) 1983 Honda V45 Magna
(Sold) 1984 Honda V65 Magna
(Sold) 1984 Kawasaki Eliminator 900
(Sold) 1988 Honda Hurricane 1000
(Sold) 1994 Kawasaki ZX-7
(Sold) 1993 Suzuki GSX-R750
(Sold) 1993 Ducati 900SS
(Sold) 1999 Suzuki TL-1000R
(Sold) 2000 Ducati 996
(Sold) 1999 Ducati ST2
(Sold) 2009 Kawasaki Concours14
2010 Ducati Multistrada 1200S (red)
Preserve wildlife, use freezer bags
joeducati is offline   Reply With Quote
Touratech MTS1200 handguard kit installed (photos) Dr. Greg Multistrada 5 Dec 28th, 2011 5:22 pm
Finally installed the Nichols FW in my 999.... ZDM Superbikes 7 Feb 27th, 2011 12:23 pm
Finally installed the Wasp puk1 kit on my Paul Smart Rbea9467 Sport Classic 20 Apr 14th, 2010 3:27 am
Finally, my vision is complete...748 CF Mono-tail Installed! Caution: multiple pics desmofetish Superbikes 19 Apr 9th, 2007 3:48 pm
Termis finally installed.... johnrg Sport Classic 12 Oct 17th, 2006 2:48 pm
