Jan 27th, 2012, 7:23 pm
12000km and leaking oil
any one heard of this ...looks to be leaking from the strain oil pick up cover ?
Jan 28th, 2012, 12:55 am
First, the filter was to be inspected/cleaned at 1000KM.
If the leak is not a hemorrhage one could consider it a minor issue until next oil service.
If it was dealer serviced the fix could be on them if you so choose.
The screen filter has a plate with four fasteners that is sealed from the factory with silicone that is grey in color.
If the filter cover was R&I by a DIYer, you are on your own. Not a difficult job but will involve draining the oil, removing the cover, reseal with silicone. Or, a trip to the dealer.
The screen is not required to be cleaned at 12000KM service but you have reached 12000KM and it should be time for an oil service anyway. (if not recently performed)
Are you certain the leak is at the screen cover? Could be from the oil drain plug also as it is in the general vicinity.
2010 Multi S Touring
1973 Honda CB 750 Four
Jan 28th, 2012, 3:46 am
yeah its definitely oozing from that join i have not touched the filter just changed the oil at 7000kms........ oh by the way its 13300km so its due for an oil service
Jan 28th, 2012, 4:38 am
Hi. I'm just putting my finishing touches to a mutley I bought that was a total write off!!. One of the (easy) things was to change the oil.
I took the plate off, drained the oil, cleaned all the old silicon off. Bought some new silicon (the recommended type) fitted it all back together........ and it leaked!! Just a weep like you describe.
The answer, is to take it all apart again and replace with a gasket mentioned and pictured on Andys great website here
Update Sep2011 - whilst Ducati's original instructions stated that the course oil screen cover plate should be sealed with a silicone based 'liquid gasket' type sealant they have now introduced the use of a 'crush' type gasket (not reusable;-) part number 78810651A
Motorcycle Info Pages - MTS12 Servicing & Maintenance > Engine Oil Change
Had to take it all apart. Fitted it dry, and no leaks!
Take care. Paul.
Jan 28th, 2012, 6:31 am
I had a bad oil filter, leaked at the seam on the top of the oil filter , like a tin can top...
You are supposed to let the "Silicone" set up for a while too...
Get a few of them gaskets , handy if you never use them..
2011 Red Multistrada Touring
Jan 28th, 2012, 9:24 am
Right on!
Snug the four fasteners till sealant barely begins to squeeze out the edge of the cover, wait an hour, then apply correct torque in a 1-3-2-4-1-3-2-4 fashion.
Jan 28th, 2012, 9:35 am
I did the 4-3-2-1 ,4-3-2-1 sequence...
Jan 28th, 2012, 2:14 pm
My bike developed a leak when the weather turned cold.
I tightened the oil filter a bit more and I have not seen any oil sense.
I think its corrected now.
2010 Ducati Multistrada 1200 S Touring - Diamond Black - with 2011 updates
1983 Honda CM450 - SOLD 9/23/2010
2009 Kymco Super8 Scooter
2007 Yamaha FZ1 Raven - Crashed
2005 Suzuki DL1000 Vstrom - Traded on MTS
1998 Honda VFR800 - Traded on DL1000
2000 Kawasaki Ninja ZX6R - Track
Jan 29th, 2012, 2:15 am
Take care. Paul.
hey thanks for that .....that gasket looks the goods and i never noticed that site before ..great stuff
Feb 1st, 2012, 1:20 am
just a follow up
I took the bike back to the dealer and they have repaired the leak under warranty as well as the service...
