Should I get bar risers? - Ducati.ms - The Ultimate Ducati Forum
Old Jan 25th, 2012, 6:02 pm   #1 (permalink)
Montanaman's Avatar
I now have my 2011 Multi S touring pretty well set up to my liking. I have about 3000 miles on it and over all very satisfied. I was wondering if risers would make a comfortable riding position even more comfortable.?? I am 5'8" 30 inch inseam and average arm/ torso length. I feel like I am leaning forward ever so slightly which is great for cornering. I plan on doing some 300 mile days and wondering if a slight riser ( 30mm) might be a good thing? I dont want to go thru the hassle of buying them and putting them unless I am fairly certain its a good trade off.
2011 MTS1200 T
2011 BWM F800GS
2009 Hyper ( gone but I have visitation rights)
Montanaman is offline   Reply With Quote
Old Jan 25th, 2012, 6:04 pm   #2 (permalink)
Kitesurfer's Avatar
Alas everyone is different. I am taller than you and I wish the bars were LOWER for my liking. Hey, what would be good would be some kind of electronically adjustable bar height that is programmable along with the Ohlins suspension settings
2010 Multistrada 1200SS White
2009 Suzuki GSX-R750 Black
Kitesurfer is offline   Reply With Quote
Old Jan 25th, 2012, 7:10 pm   #3 (permalink)
I installed risers and found the throttle cables were affected at full handlebar swing. 30 mm I believe.
I will have the shop re install them at the 15k service as the bodywork will be off and rerouting the cables will be easier.
robertmh is offline   Reply With Quote
Old Jan 25th, 2012, 9:30 pm   #4 (permalink)
les96's Avatar
Try rolling you bars back towards you, a little bit helped me get more comfortable. You will have to set your clutch and brake lever angles again but no big deal
Two many to list...then
2010 Monster 696
les96 is offline   Reply With Quote
Old Jan 25th, 2012, 9:45 pm   #5 (permalink)
Turkishexpress's Avatar
Be careful on how much you raise your bars. Sometimes even an inch or two will cause for you to have to use your delts too much causing excessive fatigue in longer rides. May even tighten your traps.
2011 Multistrada S - Street
K7 GSX-R 600 - Track Only
Turkishexpress is offline   Reply With Quote
Old Jan 26th, 2012, 12:30 am   #6 (permalink)
TimOz's Avatar
I am 6ft 2 and I like my bars raised. I did it the cheap way but this works perfectly, costs very little, gives the bars better clearance from the screen and all cables and hydraulics fit as they are.
MTS1200 raised handlebars - El Cheapo, fast and easy
They are still there as fitted almost a year and 12K km later. No one has ever noticed them.
TimOz
2010 MTS1200S Sport Black
Standard exhaust
TimOz is online now   Reply With Quote
Old Jan 26th, 2012, 11:01 am   #7 (permalink)
Sock Monkey's Avatar
Go here: Motorcycle Ergonomics
Enter your data and see if bar risers will get you where you want to be. I used this tool a lot when shopping for my next bike and at 6'0", the Multi w/ 30mm risers looked perfect.....and is.
Just FYI, 30mm is as high as you can go without replacing/moving cables.
-SM
Current:
2010 Ducati Multistrada 1200 S Sport
2008 Yamaha WR250R
Gone:
Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Bar risers Noob Sport Touring 17 Sep 21st, 2009 11:58 am
Help with risers please alon Superbikes 10 Aug 29th, 2008 2:13 pm
Bar risers gunning Superbikes 9 May 17th, 2008 9:51 am
risers for 06 xx9? cleanimages Superbikes 19 Jul 3rd, 2007 9:41 am
bar risers? We don't need no stinkin' bar risers supersparky750 Supersport 2 Sep 5th, 2006 10:56 pm
