MSTD1200 Timing belt cover. Internal clearance. - Ducati.ms - The Ultimate Ducati Forum
Old Jan 23rd, 2012, 9:32 pm   #1 (permalink)
Folks,
Can anyone confirm for me what the difference is, in the offset between the outer face of the timing belt pulleys on the Horizontal head ?
Attached photos show :
- which pully I'm having trouble with.
- the gouge it has cut into the inside of the cover itself.
- an attempt to show the offset between it and the pulley below it.
My initial guess was that these should be just about flush, as opposed to 5-6 mm gap...
Does the top pulley look like it's sticking out too far ?
Cheers,
Wit C.
unreliable heap of shit (red)
DP Top box + HFF + Alarm
11-Aug-2010
(http://www.madcogz.com/ms-data.htm)
MODIFICATIONS
DP CF tail tidy - (www.proitalia.com)
RadGuards - (radiator + oil cooler) (www.radguard.com.au)
SW Motech header guard - (www.motorradgarage.com.au)
SW Motech crash bars - (www.motorradgarage.com.au)
SW Motech Hawk radiator light mounts - (removed due to recall)
SW Motech Hawk fairing mounts - (installed after all ... looks OK)
sheepskin seatcover - (www.goodwool.com
Givi touring screen - (ebay)
mivv decat and suono slipon (http://www.pjsparts.com/)
Denali D2's - ( www.twistedthrottle.com )
SupaBrake brake flasher. ( www.vizi-tec.com )
FatDucs O2 manipulators. (removed www.performanceboulevard.com)
Touratech Handguards
powdercoated bellypans and exhaust guard
CP-Wings
Headlight protectors
WARRANTY ISSUES(wrnty) DES rear shock Replaced. (mar 2011)
(wrnty) clutch mc replaced (mar 2011)
(wrnty) 2011 recall updates, fuelling ABS and Dash (may 2011)
(wrnty) DES Rear Shock ECU replaced (jul 2011)
(wrnty) 2011 recall updates, Handsfree, switches (jul 2011)
(wrnty) pourus Cylinder Head replaced (5-12-2011 to 19-1-12)
(wrnty) sudden coolant leak at 26700+km (May 2012)
REPAIRS
(idiot) jammed gearshift. fixed now. thankyou QBE.
WEAR and TEAR(wear) Chain/Sprockets toast & rear disk at min thickness at 26,700km
REASON in SHOP today ?Unbelivably FRASERS have been unable to source a new chain for 8 days now (and counting).
651 days old and 26,700+ km travelled as at 22nd May 2012
wcieslik is offline   Reply With Quote
Old Jan 24th, 2012, 12:39 am   #2 (permalink)
Kitesurfer's Avatar
It's hard to see in the pictures, but if there was an offset, what would that do to the belt itself? Wouldn't it be always trying to jump off the pulley(s)? Or is one pully wider than the other?
2010 Multistrada 1200SS White
2009 Suzuki GSX-R750 Black
Kitesurfer is offline   Reply With Quote
Old Jan 24th, 2012, 1:05 am   #3 (permalink)
yeah... i think the belt slightly overhangs the main gear now. just a fraction though. ( between E and D )....
just curiose as i wouldnt have expected such a large offset between the outer faces of the two pulleys.
Im gonna clean up the gouge and color over it, to see if it is still hapenning...
If anyone has their cover off for whatever reason, I wouldnt mind their observations.
cheers wit c
11-Aug-2010
MODIFICATIONS
CP-Wings
REPAIRS
Old Jan 24th, 2012, 1:09 am   #4 (permalink)
Kitesurfer's Avatar
Maybe they designed it to rub on the cover in lieu of the sound of a dry clutch
Old Jan 24th, 2012, 1:15 am   #5 (permalink)
Wink
ha ( lol ). damed clever those italian designers !
11-Aug-2010
MODIFICATIONS
CP-Wings
REPAIRS
Rizoma Timing Belt Cover for my 749? st34lth Superbikes 6 Jun 18th, 2011 12:52 am
timing belt cover venting RockingM Sport Touring 7 Feb 3rd, 2011 4:15 pm
Timing Belt Cover question pcv57 Monster 2 Jan 23rd, 2010 5:58 pm
clear timing belt cover dctech7 Supersport 6 May 15th, 2007 1:22 pm
timing belt cover w/ window Will_7926 Superbikes 7 Mar 19th, 2006 2:59 am
