Motorcycle Info Pages - Ducati 1200 Multistrada > MTS1200 'Snippets'
Digital Dash Speed Display / Speedometer - How to convert kmh to mph
With ignition off, hold in the headlight flasher and the indicator cancel switch together then turn on the ignition. The main display will show 'units' and you can then use the indicator cancel to select which ones you want, save (keep the indicator cancel button depressed) and exit.
