Originally Posted by Mr Sunshine
I've never had an issue starting my bike even at 30 degrees with the stock system. 2-3 seconds max of cranking and it fires right up.
Yes, very possible.
The problems with getting a bike to start, like anything in life, would be distributed over a bell curve.
On one end is a bike with every possible variable off just enough to make getting the bike to start a royal pain.
You would be on the other end where you have little to no problems.
In the middle (on the big bulge of the bell) is where most of us are.
I do end up selling kits to riders who have just bought a new bike so they can try and maintain the new bike starting capability.
A bike with no issues whatsoever will start in less than 1 second.
A bike that is allowed to crank for a long time tends to degrade the starter motor such that it draws more current than it should.
Then even with the HICAP the bike doesn’t start instantly like it could have with an undamaged starter motor.
So some riders want to prevent that slow deterioration from getting started.
Since the kit tends to pay for itself in longer battery life they look at is as an investment that will zero out at some point in the future.
And if they keep the bike long enough it will actually have saved them money in overall cost of ownership.
HTH
