Jan 15th, 2012, 7:44 pm
Nology Spark Plug Wires
Has anyone used the Nology Spark Plug Wires?
If so does it make it easier on the starter?
Jan 15th, 2012, 9:20 pm
Official Sponsor
The Nology wires do not work as well as Magnecor.
And changing your sparkplug wires will not aid much in getting your bike to start (they might help a little but not much).
There are other factors which hinder efficient and quick starting.
Michael Heth
mheth@motolectric.com
Motolectric.com | Innovative Electrical Upgrades For Motorcycles Since 2002 |
Also available through Motolectric | Remus - Melvin - Odyssey - Shorai - Magnecor - Scotts Dampers - Traxxion Fork Upgrades - TFX Custom Shocks |
Jan 16th, 2012, 1:20 am
Official Sponsor
We have had very good results and feedback with the Magnecore
Here is a 8.5mm set shown here for the Ducati Sport classic
On top is the stock
MAGNECORE KV85 | Index
8.5mm cable 72 ohm per cm, 2.2K ohm per ft. + 10%. Comes in RED only
8 mm cable 98 ohm per cm, 3K ohm per ft. +/- 10%. Comes in Black only
7 mm cable 98.4 ohm per cm, 3K ohm per ft. + 10%. Comes in Blue Only
Pricing varies. Email us for quotes
Jan 16th, 2012, 1:36 pm
Hi JCPakbikes,
What are the very good results and feedback?
Does it start with just half of the engine turn over? Does it start without even hearing that the engine turns over?
Best
Martin
Jan 16th, 2012, 1:40 pm
Official Sponsor
First off it is much less expensive then the stock plug wires
secondly they are a little more hefty
and they come in colors
As far as perfomance goes I would say it is about the same
All that being said
Magnecore said that the 1200s do not have spark plug wires (the ignition coils are physically attached to the spark plugs).
Correct m if I'm wrong
Originally Posted by MartinM
Hi JCPakbikes,
Best
Martin
Jan 16th, 2012, 4:48 pm
So in that case you couldn't use the nology wires then anyways, correct?
Jan 16th, 2012, 5:19 pm
Official Sponsor
If what I was told is the case, yes no plug wires are used
Jan 16th, 2012, 8:33 pm
Yes they are called "coil overs" .
:: Chris Burgess ::
http://www.burgiracing.com
#104
WMRRA
OMRRA
WERA
Race bikes...2003 SV650 SBK & 2012 Triumph 675R
Street bike...2010 Multistrada S in white
