Originally Posted by Sock Monkey
With the SW Motech crash bars, you added about 20lbs of weight forward of the balance point. IMO this is the source of your "turn in", not the Barkbusters....
-SM
+1 I defintly noticed the extra weight after adding my bars too. It not extreme but it is quite noticable.
A bit like going from an empty tank to a full tank
unreliable heap of shit (red)
DP Top box + HFF + Alarm
11-Aug-2010
http://www.madcogz.com/ms-data.htm)
MODIFICATIONS
DP CF tail tidy - (
www.proitalia.com)
RadGuards - (radiator + oil cooler) (
www.radguard.com.au)
SW Motech header guard - (
www.motorradgarage.com.au)
SW Motech crash bars - (
SW Motech Hawk radiator light mounts - (
removed due to recall)
SW Motech Hawk fairing mounts - (installed after all ... looks OK)
sheepskin seatcover - (
www.goodwool.com
Givi touring screen - (ebay)
mivv decat and suono slipon (
http://www.pjsparts.com/)
Denali D2's - (
www.twistedthrottle.com )
SupaBrake brake flasher. (
www.vizi-tec.com )
FatDucs O2 manipulators. (
removed www.performanceboulevard.com)
Touratech Handguards
powdercoated bellypans and exhaust guard
CP-Wings
Headlight protectors
WARRANTY ISSUES(wrnty) DES rear shock Replaced. (mar 2011)
(wrnty) clutch mc replaced (mar 2011)
(wrnty) 2011 recall updates, fuelling ABS and Dash (may 2011)
(wrnty) DES Rear Shock ECU replaced (jul 2011)
(wrnty) 2011 recall updates, Handsfree, switches (jul 2011)
(wrnty) pourus Cylinder Head replaced (5-12-2011 to 19-1-12)
(wrnty) sudden coolant leak at 26700+km (May 2012)
REPAIRS
(idiot) jammed gearshift. fixed now. thankyou QBE.
WEAR and TEAR(wear) Chain/Sprockets toast & rear disk at min thickness at 26,700km
REASON in SHOP today ?Unbelivably FRASERS have been unable to source a new chain for 8 days now (and counting).
651 days old and 26,700+ km travelled as at 22nd May 2012
