Idle Revs @ 2k With Start Up... Normal? - Ducati.ms - The Ultimate Ducati Forum
Old Jan 8th, 2012, 9:01 pm   #1 (permalink)
Bugkiller1200's Avatar
So I recently got the Multi 1200 out of the garage for a cold weather ride after it had been sitting for three weeks. After turning the engine over the idle revs were at 2000+ (over reving at idle) while the engine was warming up. It was if it had a choke that was turned up to to ensure the engine turned over.
Is this normal: engine reving higher than normal at start up after the bike has been sitting around for a while? Idle revs went back down to ~15k after the first couple of stops.
2011 Multistrada 1200
Bugkiller1200 is offline   Reply With Quote
Old Jan 9th, 2012, 1:25 am   #2 (permalink)
sfarson's Avatar
Neil... I've noted the same after the MTS has sat in a cold garage for a few weeks. The idle RPM's tend to settle down after it has warmed up. Over the years, have had a few other bikes/makes do the same.
The Colorado Book
sfarson is online now   Reply With Quote
Old Jan 9th, 2012, 1:34 am   #3 (permalink)
idle speed
My normal idle speed immediately after startup is 1200 RPM.
Below about 5 degress Celsius it idles at 1800 for the first couple of minutes than falls back to 1200.
I wouldn't sweat it too much - I reckon Ducati did this on purpose.
R.I.P. #58
2008 848 Red/white/black - track puppy (Francesca)
2008 S4Rs Tricolore #293 (Isabella)
2011 MTS S Touring - Black (Sofia)
oleary is offline   Reply With Quote
Old Jan 9th, 2012, 8:57 pm   #4 (permalink)
I figured it was no biggie... Thanks for the reassurance guys!
Old Jan 10th, 2012, 4:50 am   #5 (permalink)
I've not seen mine idle faster when cold and have always questioned it - 1200 rpm at startup no matter how cold it is. Sounds like its normal +/-.
falcodave is offline   Reply With Quote
Old Jan 10th, 2012, 1:22 pm   #6 (permalink)
I was out for toot yesterday.
At +7 degrees celsius it idled at about 1600 for a couple of minutes then dropped back to normal. I think it is designed this way.
R.I.P. #58
Old Jan 10th, 2012, 1:23 pm   #7 (permalink)
Define "cold".
I've been out at -5 Celsius.
R.I.P. #58
Start up idle jonecin Sport Classic 5 Nov 5th, 2011 7:27 pm
whats "normal" idle RPM for 1098 jeremyh007 Superbikes 10 Jan 11th, 2011 12:02 am
Question: 749s Cold Start / Fast Idle Lever normster Superbikes 4 Nov 6th, 2009 7:44 pm
Please Help: Bike Idle start problem anaki Superbikes 9 Nov 25th, 2008 11:26 pm
Paul Smart won't start or idle without help gordsboyroy Sport Classic 12 Oct 7th, 2008 5:56 pm
