PCV speed input - Ducati.ms - The Ultimate Ducati Forum
Old Jan 7th, 2012, 2:09 pm   #1 (permalink)
PCV speed input
Anyone out there who actually has a PCV installed been able to figure out how to provide speed data to the unit?
Thanks.
Long story version:
The PCV takes a single wire input that is expecting a square wave at a varying frequency to interpolate speed. Prior Ducati's used a different speed sensor than the MTS. The MTS uses a hall effect speed sensor that provides rear wheel speed info for speedometer, ABS and DTC purposes. The wiring diagram for ABS/S models show the two wire speed sensor going into the ABS computer, then a single wire identified as speed signal going between the ABS computer and the BBS (black box controller under the seat). I tapped off the speed sensor lead itself (tried both individually), but the PCV didn’t see it, since I suspect it is not the type of signal it needs. On a different note, I contacted SpeedoHealer to find out if they had an application for this bike that doesn't screw up the ABS or DTC and they said their device works fine by tapping into the speed signal wire that goes between the ABS and BBS units. Since I would guess it works similarly, I am thinking that the signal from the sensor is being processed by the ABS unit before going out to the BBS. My bike is a standard with no ABS black box, so the wiring is a bit different from the ABS version wiring diagram I have, with different color wires at some critical places to this application. If anyone has a Standard Model wiring diagram I could “borrow” that would be helpful too.
2010 Multi 1200 Std
2005 DRZ400
2007 S2R1K (sold)
2007 DL650 "weestrom" (sold)
1981 Honda CB900 Custom (sold)
patorojo is offline   Reply With Quote
Old Jan 7th, 2012, 8:29 pm   #2 (permalink)
Turkishexpress's Avatar
Need Maintenance Manual
The manual for the standard version is in there as well. Just be ware that the draft version does have a lot of mistakes in it. Its pretty good overall but its not end all be all...
2011 Multistrada S - Street
K7 GSX-R 600 - Track Only
Turkishexpress is offline   Reply With Quote
Old Jan 7th, 2012, 9:29 pm   #3 (permalink)
Thanks. I actually ended up finding a standard wiring diagram late today. Unfortunately it shows that the speed sensor lead goes directly into the BBS with no other output. Since I had already tried tapping into this line to no avail, I may be out of luck since I don't have an ocsilloscope to see what is really going on I have an email into Dynojet.
2010 Multi 1200 Std
2005 DRZ400
2007 S2R1K (sold)
Old Jan 8th, 2012, 10:51 am   #4 (permalink)
I installed a PCV on my bike and saw no mention of a speed sensor in the directions. Perhaps Dave has revised the setup?
robertmh is offline   Reply With Quote
Old Jan 8th, 2012, 10:53 am   #5 (permalink)
Red face
Oops, my mistake. I have the redline version.
Old Jan 9th, 2012, 2:40 pm   #6 (permalink)
Mr Sunshine's Avatar
And the speed sensor would be for what?
:: Chris Burgess ::
http://www.burgiracing.com
#104
WMRRA
OMRRA
WERA
Race bikes...2003 SV650 SBK & 2012 Triumph 675R
Street bike...2010 Multistrada S in white
Mr Sunshine is offline   Reply With Quote
Old Jan 9th, 2012, 7:09 pm   #7 (permalink)
I have the LCD200 which logs data from the PCV and attached autotune wide band 02 sensors. In order to better analyze the AFR data from on road sessions, it would be very helpful to have speed (and by extrapolation, gear data) so I can narrow my analysis and target my fuel map changes to exactly what I am trying to effect.
2010 Multi 1200 Std
2005 DRZ400
2007 S2R1K (sold)
Old Jan 10th, 2012, 3:59 pm   #8 (permalink)
The PCV can take in speed to calibrate gear or use the 0-5v input and use the analog input of the gear position sensor on this bike. There is a 3 pin connector under the seat for gear position. Tap into the signal wire of that connector and using software 1.0.6.1 you can choose if you want GEAR to be calibrated from speed or voltage. Choose voltage and you are good to go.
DynojetResearch is offline   Reply With Quote
Old Jan 10th, 2012, 8:10 pm   #9 (permalink)
OK, I see this in the software and will try it. Can the PCV then extrapolate the speed (known RPM and Gear) or will I have to calculate that manually?
2010 Multi 1200 Std
2005 DRZ400
2007 S2R1K (sold)
Old Jan 10th, 2012, 8:47 pm   #10 (permalink)
Are you sure he won't need a resister in there? I ask because I did the same thing for my GPX data logger on my SV which has a 5v GPS and a resister was required or it couldn't tell the difference between a couple of the gears due to how the voltages were spread.
:: Chris Burgess ::
#104
WMRRA
OMRRA
WERA
GPS speed vs. Speedo speed, GT1000 ducatisRme Sport Classic 4 Mar 14th, 2012 9:06 pm
low speed surging and high speed lugging meloman Monster 29 Mar 25th, 2011 9:38 am
MTS input tahoest2 Multistrada 3 Aug 24th, 2009 1:02 pm
The Futility of Speed for Speed's Sake Bikehead Sport Classic 12 Dec 18th, 2007 1:09 am
6-speed gear box in a 5-speed case whirlybird Supersport 20 Jan 9th, 2007 11:29 am
