Dumb question - rear tire removal - Ducati.ms - The Ultimate Ducati Forum
Old Dec 29th, 2011, 10:48 am   #1 (permalink)
For those that have done it: Do you *really* need to remove the exhaust to pull the rear tire? Can you just loosen it? Or wiggle the rear tire by it without loosening/removal? Any issues fitting it back on?
I was looking at it the other day hoping to do a 'quick' rear tire change at the local shop by bringing my wheel down to them, and 'quick' didn't appear possible after reading the manual and seeing the exhaust removal instructions..
Thanks in advance!
brianc is offline   Reply With Quote
Old Dec 29th, 2011, 11:12 am   #2 (permalink)
you either have a bad manual or are reading the wrong pages.
You don't need to remove the exhaust to remove the rear wheel.
jcns is offline   Reply With Quote
Old Dec 29th, 2011, 11:13 am   #3 (permalink)
You do have to pull the exhaust. It is easy first remove the top silver shield to gain easy access to the bolt that will loosen the exhaust, but first remove the three screws from the heat shield and remove this first. Also when you refit exhaust don't tighten the main bolt just yet, leave it a little loose so you can easily re-align the heat shield holes, these can be a bitch if you go crank the main bolt down with out making sure the three holes are aligned. Also when you loosen the big bolt up you have to twist the exhaust forward so that the hook under neath will disengage. It's all pretty easy just take your time.
Socalrider is offline   Reply With Quote
Old Dec 29th, 2011, 11:47 am   #4 (permalink)
i also didn't see anything about how to remove the exhaust - found that there's a pin on the pipe, and a slot in the exhaust. loosen the clamp screw, rotate the exhaust and it slides right off w/o removing the heat shield. Next comes the battle getting the axle nut off - long lever needed. Now if i can find someone to mount my new tire ! good luck
falcodave is offline   Reply With Quote
Old Dec 29th, 2011, 12:20 pm   #5 (permalink)
My848's Avatar
I've done it and yes, you do have to remove the slip-on...
and that slip-on doesn't want to come off...want a pain in the azz that was...
2011 Ducati MTS1200 ABS (red)
2010 Ducati Monster 696 (sold)
2009 Ducati 848 (Red)
2009 Kawa Ninja 250 (sold)
2003 Honda Shadow 750 (sold)
2002 Honda Rebel (sold)
2001 Triumph TT600 (sold)
1995 Honda VLX600 (sold)
http:my848.kicks-ass.net
My848 is offline   Reply With Quote
Old Dec 29th, 2011, 12:57 pm   #6 (permalink)
Turkishexpress's Avatar
Easy way...
Remove the shield (4 torx screws)
Loosen main clamp screw where the slip on connects to cat.
Remove slip on by rocking it towards and away from you if you're facing the right side of the bike. Sometimes a rubber hammer helps a little.
2011 Multistrada S - Street
K7 GSX-R 600 - Track Only
Turkishexpress is offline   Reply With Quote
Old Dec 29th, 2011, 1:47 pm   #7 (permalink)
My848's Avatar
Originally Posted by Turkishexpress View Post
Easy way...
"rocking it" +1
Old Dec 29th, 2011, 1:48 pm   #8 (permalink)
Incorrect on both counts. I should have specified: this is for a 2011 ducati mulitstrada 1200 S, which has the exhaust muffler partially covering the rear wheel on the right (removal) side. The manual used is the ducati service manual, and specifies removing the muffler as a pre-requisite task to remove the rear wheel from the motorcycle.
@ the rest - thanks for confirming, I thought I might be able to skate by removing it, but guess not.
Old Dec 29th, 2011, 1:49 pm   #9 (permalink)
Easy way...
Perfect! Thank you I'll give this a shot.
Old Dec 30th, 2011, 6:45 am   #10 (permalink)
Mine came off without doing anything to the muffler. It was a squeeze though. I recall getting mad at it.
Mr Hankey is offline   Reply With Quote
Stupid, stupider, stupidest, dumb tire question slowerthan Sport Classic 16 Jan 10th, 2011 6:23 pm
Rear tire rock deflector removal? zimm17 Multistrada 17 Aug 26th, 2010 8:11 pm
ST3s rear tire removal rino56 Sport Touring 25 Nov 20th, 2009 11:03 am
dumb rear stand question Bones!!! Superbikes 6 Sep 9th, 2009 3:10 pm
Rear Tire Removal 93Octane HyperMotard 16 Feb 18th, 2009 6:20 pm
