UNKNOWN DEVICE Error code ?? - Ducati.ms - The Ultimate Ducati Forum
Old Dec 26th, 2011, 3:38 am   #1 (permalink)
Hi All
Merry Christmas and a great New Year to you All
I have bought a damaged repairable Multi and I have repaired it to the stage where all I have had to do is clip the clock in and fire it up.
The original clocks were smashed so I bought a second hand clock set and had the info downloaded from the original into the new clock. I live in the UK and a guy in the UK can do this. Effectively the new clocks should now have the same info as the old clocks.
Soooo this morning (with much anticipation!!) I clipped the new clock set in. It did indeed light up and the old mileage showed up on the screen which would indicate that the original info has been transferred over.
BUT an error code comes up...... UNKNOWN DEVICE
I haven't tried starting as there is no petrol in the tank, but does anyone know what this error code usually signifies. Could it simply be the new clocks?
Thanks all. Paul.
cad169 is offline   Reply With Quote
Old Dec 26th, 2011, 4:21 am   #2 (permalink)
geobryrap's Avatar
G'day Paul,
From workshop manual,
Error message............................Error
UNKNOW DEVICE.........................Uknown control unit
"maybe guy can't do this"
hope this helps George.
George,50 and back on 2 wheels after a 20+ year break and loving it! 05 MTS1000DS Red (SOLD), 08 Suzuki GSXR-750 (SOLD), 05 CBR1000RR Trackhack and NOW 2010 MTS1200S Touring RED
geobryrap is offline   Reply With Quote
Old Dec 26th, 2011, 4:51 am   #3 (permalink)
Hi George.
Thanks for that. I have the manual and I know it means unknown control unit, but what does that mean?
Is it the clocks, the ECU. Is it something to do with a device that has nothing to do with Ducati, ie an alarm or the tracker that is apparently fitted?
Anyone had this code pop up?
Thanks.
Paul.
Old Dec 26th, 2011, 6:30 am   #4 (permalink)
sterik's Avatar
Hi Paul,
Meaby you can try the next:
Hold the Mode and Flash switch together. Put on the power with the red switch. Normaly this gives the menu for switching between miles/km etc.
Succes.
Erik
Netherlands
sterik is offline   Reply With Quote
Old Dec 26th, 2011, 6:50 am   #5 (permalink)
Originally Posted by sterik View Post
Hi Paul,
Succes.
Erik
Netherlands
This as a test to see if the clock set works ?
(if this also result in a error..... then the clock set isn't set properly?)
And a "zwaai" to Erik, about 20 miles away
Ted038 is offline   Reply With Quote
Error Device DES jkroner Multistrada 5 Jul 4th, 2011 9:07 am
r.6 error code ? Xeilaxtu HyperMotard 9 Jan 24th, 2011 9:10 pm
Error code 38.0 can HyperRyan HyperMotard 6 May 28th, 2010 7:51 am
Error code !!! sargie34 HyperMotard 10 Sep 28th, 2009 4:09 pm
Error Code 6.0 - anyone know what it is? Ssssusanq Multistrada 0 Jun 19th, 2009 11:26 am
