Scottoiler or Pro-Oiler - Ducati.ms - The Ultimate Ducati Forum
Old Dec 25th, 2011, 3:32 pm   #1 (permalink)
My last bike with chain was an Africa Twin, and I installed a Scottoiler, that was very difficult to set, if I set it for urban use, when went to the road it split too much oil, and vice versa.
I was close to replace the Scottoiler for the Pro Oiler many times, but I never did.
I replaced the Africa with a FJR 1300, and for years I had the simplicity of the no-chain-bike.
Now I'm close to buy a new MTS and the chain lubrication problem will return.
Why Scottoiler or Pro-Oiler? Which one are you using?
DiasDePlaya is offline   Reply With Quote
Old Dec 25th, 2011, 9:37 pm   #2 (permalink)
Kitesurfer's Avatar
Manual: spray can every few hundred kms. At least you get to pick up any chain related problems sooner rather than later.
2010 Multistrada 1200SS White
2009 Suzuki GSX-R750 Black
Kitesurfer is offline   Reply With Quote
Old Dec 26th, 2011, 12:20 am   #3 (permalink)
Great Scott
I fitted a standard gravity fed Scott oiler to my multi. It's great! No more grimy chain wax and easy cleaning....Plus added life expectancy of my chain! I see BMW offer it as an option on their chain driven bikes now too....so it must have passed a test.....
They have a better electronic version too, similar to the pro oiler.... But I prefer the simplicity and ease of fitting of the gravity fed version.
yes....one does have to change the setting often as the outside temp changes the viscosity and so the runny ness of the oil....but the best part is the cleaning is soooo easy compared to a can o'wax that I don't mind the fling off!
multi rider is offline   Reply With Quote
Old Dec 26th, 2011, 6:34 am   #4 (permalink)
The pro-oiler was my first (and only) oiler (on my honda hornet 600), but when i bought a new bike, i didnt build it over due to difficult settings, some strange malfunctions (after 4 years use) & (for me) hard to build in and switched to spraycans.
One of the nicest features is it takes any oil, even regular motoroil, so no expensive refills here
Scottoiler has the Esystem, an electroniccal controlled system, which seems to be the evolved version of the pro oiler and it looks nice, the display with G-force-indicator is nice for gadget-loving-nerds like me but the oilcontainer seems rather small, at least on a longer motorbikeholiday you'll have to refill, or buy the additional lubetube.
A cheaper solution is the original scottoiler (MK1), or the new model the Vsystem. Both work by attaching something to the bike-engine so when the bike is running a vacuum is resolved so the oiler starts dripping oil , the amount of dripping can be managed offcourse.
These versions can also be fitted with the lubetube.
Original scottoiler oil is advertised, since with "gravity" systems different oils result in more/less drips.
In the netherlands the OSCO oiler (Osco chainoiler - Home) is very popular (but the english translation doesn't work on that site?)( english review) , and is a combination between the on-bike-build of other oilers, and non-automatic-spraying of the spraycans.
Every other 200 miles or so you pull on a knob and the chain gets oiled, you decide when it gets oiled. (best is just before tankstop of before getting home/@hotel, since rthe chain is nicely hot and oil has some time to settle in)
Very simple in use & building on your bike, no electrical wires or attaching to valves and therefore almost foolproof
Anyway, I would choose the scottoiler Esystem cause i am a gadget nerd
Ted038 is offline   Reply With Quote
Scottoiler on a Streetfighter srady StreetFighter 6 Jul 15th, 2010 7:44 am
748 916 996 998 - Scottoiler duncpowell@hotmail.com Superbikes 0 Mar 3rd, 2010 2:35 am
Scottoiler Installation Labrador-Lance Sport Touring 14 Jul 23rd, 2007 7:42 pm
Scottoiler? jerry5 Ducati Motorcycle Chat 6 Jan 12th, 2007 6:46 pm
scott oiler vs pro oiler wolff Sport Touring 1 Sep 9th, 2006 9:22 pm
