Clutch - Ducati.ms - The Ultimate Ducati Forum
Old Dec 24th, 2011, 10:12 pm   #1 (permalink)
Clutch
Any one out there with some advice.....
The last two days my clutch has been slipping very badly....not all the time, but intermittently.
It's almost like the lever remains "pulled" in once I have actually released it....like as if a return spring has gone soft and is not pushing the clutch back to release it....
Could it be water has got in somewhere? Bike has been in the rain recently.
Is there an adjustment perhaps? It's a real problem because I almost come to a grinding halt....Bikes only done 3600miles
Appreciate your input!
multi rider is offline   Reply With Quote
Old Dec 24th, 2011, 11:47 pm   #2 (permalink)
djz
take it to the dealer
Mine is getting soft feeling like spring are weak 7000 miles .
You have so few miles I would think Ducati should fix
djz is offline   Reply With Quote
Old Dec 25th, 2011, 12:06 am   #3 (permalink)
Hmm, you might want to check with TimOz. I recall him having a similar problem. I believe it was traced to a sticking actuator shaft (the long one that goes through the engine from the clutch servo to the pressure plate bearing).
Oops, I remember now, it wasn't the shaft sticking, it was the piston inside the clutch servo itself. A new servo solved the problem, I believe.
R.I.P. #58
2008 848 Red/white/black - track puppy (Francesca)
2008 S4Rs Tricolore #293 (Isabella)
2011 MTS S Touring - Black (Sofia)
oleary is offline   Reply With Quote
Old Dec 25th, 2011, 1:16 am   #4 (permalink)
+1
I had exactly this same thing. Also seemed worse in the rain, which I cant explain. no problem pulling the clutch but when releasing it, it would not engage smoothly. Rather, it would slip, then suddenly engage. Very tricky in heavy traffic ( in the stnking rain ). Problem was explained as a sticking piston in the clutch slave cylinder. Mine was replaced under warranty. I understand this is a 'known issue'.
Cheers,
WitC
unreliable heap of shit (red)
DP Top box + HFF + Alarm
11-Aug-2010
(http://www.madcogz.com/ms-data.htm)
MODIFICATIONS
DP CF tail tidy - (www.proitalia.com)
RadGuards - (radiator + oil cooler) (www.radguard.com.au)
SW Motech header guard - (www.motorradgarage.com.au)
SW Motech crash bars - (www.motorradgarage.com.au)
SW Motech Hawk radiator light mounts - (removed due to recall)
SW Motech Hawk fairing mounts - (installed after all ... looks OK)
sheepskin seatcover - (www.goodwool.com
Givi touring screen - (ebay)
mivv decat and suono slipon (http://www.pjsparts.com/)
Denali D2's - ( www.twistedthrottle.com )
SupaBrake brake flasher. ( www.vizi-tec.com )
FatDucs O2 manipulators. (removed www.performanceboulevard.com)
Touratech Handguards
powdercoated bellypans and exhaust guard
CP-Wings
Headlight protectors
WARRANTY ISSUES(wrnty) DES rear shock Replaced. (mar 2011)
(wrnty) clutch mc replaced (mar 2011)
(wrnty) 2011 recall updates, fuelling ABS and Dash (may 2011)
(wrnty) DES Rear Shock ECU replaced (jul 2011)
(wrnty) 2011 recall updates, Handsfree, switches (jul 2011)
(wrnty) pourus Cylinder Head replaced (5-12-2011 to 19-1-12)
(wrnty) sudden coolant leak at 26700+km (May 2012)
REPAIRS
(idiot) jammed gearshift. fixed now. thankyou QBE.
WEAR and TEAR(wear) Chain/Sprockets toast & rear disk at min thickness at 26,700km
REASON in SHOP today ?Unbelivably FRASERS have been unable to source a new chain for 8 days now (and counting).
651 days old and 26,700+ km travelled as at 22nd May 2012
Last edited by wcieslik; Dec 25th, 2011 at 2:37 pm. Reason: corrected master to slave cylinder
wcieslik is offline   Reply With Quote
Old Dec 25th, 2011, 4:52 am   #5 (permalink)
TimOz's Avatar
If you want to wade throught he world's longest thread try here:
My bike tried to kill me today - clutch fail
In short, I have one of the early bikes and my clutch was playing up badly in the wet. It would disengage and then suddenly engage randomly. Nasty. After much stuffing around it turned out the be the slave which I had to replace with a DP upgraded part to get back on the road. If I had time I would have got an Oberon or Evoluzione replacement one instead. Cheaper and probably better engineered.
In any case you symptoms match mine in many ways. My clutch has been faultless since the slave upgrade.
Good luck.
TimOz
2010 MTS1200S Sport Black
Standard exhaust
TimOz is online now   Reply With Quote
Old Dec 25th, 2011, 5:38 pm   #6 (permalink)
Big thanks
Thanks folks for the advice.
I will probably go to the dealer for a warranty replacement. I didn't realise that the model may have issues with this....
Let's just hope it happens when I get to the dealer.... You know how stupid one feels when standing there complaining and it doesn't do it just at that precise moment.
Thanks also for answering on Xmas day! Hope you all had a good'n!
PS on the plus side wifey bought me the rizoma timing belt cover....I even managed to escape for 20mins to fit it....pure bling just love seeing those cogs and belts spinning around....
Running steel clutch pack in an hard anodized clutch basket... ZDM Superbikes 9 Jul 6th, 2010 4:36 pm
Will a 749 Radial Clutch Master Cylinder Lighten the 900SS Clutch Weight? robnobrakes Ducati Motorcycle Chat 4 Aug 11th, 2009 4:34 pm
Instructions for Installing New Clutch Plates and a Clutch Basket_1999 748S smeres Superbikes 3 Oct 17th, 2008 11:39 am
Picked up my '01 996S! Newb to Slipper and Dry Clutch...pulsating clutch handle? Dana Superbikes 13 Jun 7th, 2007 6:37 pm
