MS 1200S touring - carbon belt cover install? - Ducati.ms - The Ultimate Ducati Forum
Old Dec 19th, 2011, 8:29 pm   #1 (permalink)
TexBB's Avatar
I will have my hands on a carbon fiber belt cover set in the next day or two that I ordered from OPP Racing (Christmas deal at 15% off all carbon) I love carbon, it's an affliction or addiction, not sure which.
My dealership said the installation was a 2 hr operation that will cost approx. $180.
I replaced the plastic covers with carbon fiber on my 999 a few years back. No big deal with that bike, it was quick and easy. The lower piece on the Multistrada looks relatively straight forward, I'm more concerned with the top two pieces.
What has to come off? Thanks for your help.
2011 Ducati Multistrada 1200S touring
2001 DRZ 400S
2006 KTM 525 EXC
TexBB is offline   Reply With Quote
Old Dec 19th, 2011, 9:27 pm   #2 (permalink)
Kitesurfer's Avatar
It's split into two pieces, I presume to make it possible to remove it without having to separate the engine from the frame, so it shouldn't be too hard... Having said that, it does look like it's tucked away up there behind lots of stuff.
Maybe you could do the lower one yourself then get them to do the upper one on the 24,000km service?
2010 Multistrada 1200SS White
2009 Suzuki GSX-R750 Black
Kitesurfer is offline   Reply With Quote
Old Dec 20th, 2011, 6:44 am   #3 (permalink)
MTScott2's Avatar
Images: 5
What fun would that be?
I say dive right in there and have at her...
Ifin you get stuck , well put it all back together and then take it to the shop and let them charge you...
2011 Red Multistrada Touring
Old Dec 20th, 2011, 7:42 am   #4 (permalink)
I only replaced the lower part, the upper is hardly visible...
Ducati Multistrada 1200s, Termi titan, Carbon equipped.
MrSweden is online now   Reply With Quote
Old Dec 24th, 2011, 11:54 am   #5 (permalink)
mts 1200 belt cover
send it back and get the rizoma 1 piece, 10 minute job to fit ,looks great.
frazer
frazer is offline   Reply With Quote
Old Dec 24th, 2011, 2:43 pm   #6 (permalink)
TexBB's Avatar
rizoma
The rizoma belt cover I saw is a 3 piece part also.
Some companies only sell the lower piece. Probably because the top two parts are hard to see and even harder to install.
I'll try to install over Christmas holidays. We'll see how it goes.
2001 DRZ 400S
2006 KTM 525 EXC
Old Apr 3rd, 2012, 9:34 pm   #7 (permalink)
How did you go with installing the top two pieces of the belt covers?
ecca is offline   Reply With Quote
Old Apr 3rd, 2012, 9:39 pm   #8 (permalink)
TexBB's Avatar
carbon belt cover
actually it was a three piece set. the bottom two went on very easily and quickly. the top was another story. I had to remove the tank and cut the zip ties to move the brake lines from the abs unit. the lines run along the upper right side of the trellis frame. I cut the ties, moved the lines to the outside and wiggled the old part out and the new cover in.
worked fine. the three pieces were just like the 3 piece oem covers I removed. took awhile but was worth it.
2001 DRZ 400S
2006 KTM 525 EXC
Old Apr 3rd, 2012, 9:56 pm   #9 (permalink)
Thanks for letting me know.
Carbon belt cover? ch'dim Sport Touring 2 Mar 10th, 2011 6:29 pm
SF/1098/1198 carbon belt cover set (Shifttech) asado Parts and Accessories 3 Oct 14th, 2010 10:27 am
Rizoma Timing Belt Cover Install? 3cRider StreetFighter 20 Aug 17th, 2010 2:48 pm
1098-1198 Carbon Fiber Belt Cover Set moto Motowheels 1 Apr 7th, 2009 1:05 pm
Carbon Belt Cover on Hyper install, anything I need to know? josephvman HyperMotard 1 May 3rd, 2008 2:39 pm
